need engine cleaning help
Old Mar 5, 2006 | 08:51 PM
PAformula's Avatar
the engine on my fiance's GTA has never been cleaned before we bought the car. I'm trying to get the engine bay cleaning up before stripping the car for paint. The valve covers have what appears to be baked on oil on them and I can't get it off. I've tries engine degeaser and oven cleaner, no luck. Any ideas's?
Old Mar 5, 2006 | 08:54 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Steam cleaning? If that and the engine cleaner don't work, then you may have to get to scrubbin...
Old Mar 5, 2006 | 09:07 PM
PAformula's Avatar
Tried scrubing and steam cleaning, no luck.... Would brilo pads ruin the paint on the valve covers?
Old Mar 5, 2006 | 10:13 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
If youre going to consider brillo pads, you might start with those 3m type plastic scrubby pads...at least those wont hurt paint?
Then if that doesnt work, try steel wool/brillo?
Perhaps a wire brush?
Old Mar 5, 2006 | 10:23 PM
PAformula's Avatar
thanks for the help, time to get aggresive with the cleaning.
Old Mar 6, 2006 | 05:26 AM
casebaseball205's Avatar
power wash with a degreaser
Old Mar 10, 2006 | 09:04 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
just get new valve covers... they are cheap enough
Old Mar 10, 2006 | 11:33 PM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Just strip the stuff off with a fine wire brush attached to a drill and repaint them. Take them off so you can do a real good job.
Old Mar 10, 2006 | 11:56 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
true statement right there
Old Mar 11, 2006 | 12:00 AM
PAformula's Avatar
Repaint or replace at this point. I started using a scotch-brite pad with degreaser and it started taking the paint off. Oh well, I really didn't expect it to be easy, nothing ever is with these cars.
Where should I look for replacements? The thing that worries me abot painting is the heat, dirt, and trying to clean again after painting.
Old Mar 11, 2006 | 12:56 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
You can get new ones at www.summitracing.com or any store that like. They make some fantastic edelbrok valve covers for center bolt you might want to look into
Old Mar 11, 2006 | 02:52 PM
Car: 91 formula
Transmission: t5
if you just want stock ones go to the junkyard.... ill be getting a set of those grey ones that i can sell in about 2 weeks if your interested pm me
Infested
May 22, 2018 11:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
