I have a problem....
Old Apr 11, 2001 | 10:47 PM
92GTA's Avatar
I drove through some white paint that was on the ground in parking lot of my apartment complex and it splattered up onto the front fender and rear quarter panel on the passenger side of my GTA. It didn't just splatter, it left 2 6 to 12 inch long lines of paint on the front fender and spots all over the quarter panel! It's been there for about a month now and I'm about to do my spring wax job.
What's the best solvent/cleaner/method etc. to remove this stuff??? It appears to be oil based and it's pretty thick. My paint is 2 stage so it does have a clearcoat.
Thanks in advance!
www.TransAmGTA.com
1992 GTA (226 made), 1 of only 18 "Dk. Jade Met." 92 GTA's, My Window Sticker, LB9, 700R4 4-Speed, T-Tops, Grey Leather, every available option except G92, J65 and U1A.
Current Mods/Upgrades: 80 Series Dual Outlet Flowmaster, TPIS Air Foil, K&N Air Filter, and Mobil 1.
Future Mods/Upgrades: None but a complete restoration.
Best Track Time: 14.6sec@96.6mph
"If it ain't broke, fix it til it is!"
Webmaster www.TransAmGTA.com
My 3rdGen Firebird Message Board!
[This message has been edited by 92GTA (edited April 11, 2001).]
Old Apr 11, 2001 | 10:52 PM
RARE-ROC-Z's Avatar
best bet would be take it to a local body shop and ask them they will know the best!! and then think about it.. maybe they will even take it off for a cheap price. just confess how much you love your car and try to make a deal! always works for me
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Apr 11, 2001 | 10:53 PM
TwicK91's Avatar
Uh why would you leave it there for a month?!. I would try a claybar and maybe some of the 3M products like the swirl remover.
Old Apr 11, 2001 | 10:55 PM
Kandied91z's Avatar
man i hope it isn't the paint that they use to make parking and street line, once that stuff dries it's nearly impossible to get off without ruining your paint in someway, I tried every chemical known on my last ride and it wouldn't come off!! I wish you luck
Old Apr 11, 2001 | 11:45 PM
92GTA's Avatar
Well I don't think it's the stuff they use to paint the street. The reason I left it there is I was planning on having a body shop do it when I got my tax return but I ended up getting a new computer and paying off bils so now I'm broke and have to do it my self.
What about paint thinner? I do have a clearcoat so that shouldn't hurt it any right?? I'll see if I can get a clay bar...
Old Apr 12, 2001 | 06:31 AM
Dr G's Avatar
Try a cutting compound like "T-Cut" - see if that works. Takes a lot of time though but gives a good finish. Mind you I've never tried it on a car splattered with that amount of paint before.
Old Apr 12, 2001 | 10:17 AM
CodySmurfTA's Avatar
I run into this problem ALL THE TIME with cars I work on. USE:
1. CLAY BAR. Since it is still kinda fresh it should come off with this.
2. 3M Swirl Mark Remover or something else with a very mild abrasive, if the clay doesnt totally work.
3. 3M Rubbing Compound if all else fails. Be careful with this, only use as much as you have to to phase the white paint.
4. After the white paint is removed, wash the car with DAWN to get all the crap, old wax, and 3M residue off. Clay Bar the car too so the wax will stick to the paint for a while, not to the contaminants on the paint :P
Good Luck, post if you have any more questions! Paint is not hard to remove if you have the right products.
92 Formula L98
96 Formula- FOR SALE
99 Trans Am
www.zainobros.com
www.greatbrakes.com
Old Apr 12, 2001 | 10:19 AM
92GTA-
Paint thinner might also work. Once again, use just enough to try it out, then if it doesnt hurt the clear (it shouldnt) then go for it if it works.
Old Apr 12, 2001 | 12:58 PM
theformula's Avatar
Why don't you do the most obvious thing first and use a stage 1 remover or clear coat scrub my Meguires. Always start off with the LEAST abrasive stuff and work you way up. If that doesnt work try a little rubbing compound in
water... Goof off has worked for me as well.
You have to be out of your mind to use paint thinner on your car. It wasn't a good idea letting it sit there for a month before attempting to remove it. You should of immediately attempted to remove it.
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited April 12, 2001).]
88fastgta
Sep 9, 2010 08:58 AM
88fastgta
Sep 26, 2009 09:04 PM
Mirocz87
Aug 15, 2009 06:25 PM
1quik4
Jun 17, 2009 01:10 AM
sschevy400
Mar 16, 2009 12:45 AM
