Engine clean up
Old May 8, 2007 | 09:10 AM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Engine clean up
how do i clean my engine bay up without spending alot of money??
Old May 8, 2007 | 09:26 AM
Firebat's Avatar
Re: Engine clean up
Do you mean actually cleaning up by using degreasers/chemicals? Or do you mean give an engine bay a clean look by removing/hiding stuff like wires?
Old May 8, 2007 | 10:07 AM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Engine clean up
o no doubt hiding and removing without harming. degreasing and using chemicals is a must when you live around here and everyone wants to see the engine not what the engine can do...im more for doing than showing but if they want a show i want to give them a good one so i wanna remove hide stuff.
Old May 8, 2007 | 10:28 AM
Firebat's Avatar
Re: Engine clean up
Start by removing stuff you don't need if you can live without it.
Remove the washer jug and all of the hoses going to/from it.
Remove cruise control and all of the wires/hoses/lines for it.
Remove A/C if your area never sees hot weather or if you never drive it in extremely hot weather.
Remove the big overflow tank and get a small coolant overflow tank from summitracing/jegs. Then locate it in the nose, in front of the radiator, where it can't be seen.
Thats some basic stuff.
Old May 8, 2007 | 10:35 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Engine clean up
Here ya go.
https://www.thirdgen.org/forums/tbi/...ean+engine+bay
Old May 8, 2007 | 01:14 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Engine clean up
thank you very much. i bought a cheap open element and it was too big so i relocated my coil to the farthest left bolt that holds the windshield wiper motor and ran a wire from the ground strip on the pass side to the back of the coil to assure a good ground. it look ok. then i thought, hey why not relocated that heater valve farther back out of the way, in the middle of this i snapped one of the nipples off of the valve, so i grabbed a copper T and just ran all of the lines to this.
Old May 8, 2007 | 01:49 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Engine clean up
May I see pictures of the coil relocation? I have a 1.25 drop base and it just sits on my coil. if it were .25 lower then I'd be fine. Let me know...thanks.
P.S. I might buy the .875 drop base and the non drop no rasied base and the .5 raised base
So this way I have all possibilities to change it up.
PICTURES!!!
Old May 8, 2007 | 02:04 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Engine clean up
i would really like to post pics on here for evryone but im not sure how to do that
Old May 8, 2007 | 02:42 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Engine clean up
Click Post Reply. Then scroll down to MANAGE ATTACHMENTS. Then wherever they are saved UPLOAD them and your good to go. You can only post 3 a post..so if you have more than 3 to post...make a couple posts.
Infested
May 22, 2018 11:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
