Painting Throttle Body?????
Old Mar 7, 2008 | 08:44 AM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
Axle/Gears: 2 series 2.73 drum
Okay well I've searched endlessly and I can't find anyone who has painted their throttle body. I've just finished polishing my plenum and runners from 87 305 trans am. They came out great but I can't help noticing how crappy the throttle body looks infront of them. It looks like a pain to try to polish so I thought I'd throw a coat of primer and gloss black on it and mabye blue paint the tpi logo or something. Any thoughts on that? Tips or suggestions or why it won't work? Did a coolant bypass so I don't think heat will be an issue but I could be wrong. Help please.......if you know a link for similar pictures it would be helpful too........
Old Mar 7, 2008 | 09:39 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Painting Throttle Body?????
Polished throttle bodies look nice. Might be a pain but it can be done with a dremel tool, or drill and a few felt bobs and some polishing compounds. Your call. I've seen the results of painted TPI intakes, including the throttle body and it looked nice for a while. Later it looked like a blistered mess. But, might have been shoddy prep work? Again, your call. If you do paint, might consider high temp paint..just a suggestion.
Good luck
Old Mar 9, 2008 | 08:37 PM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
Can anyone give me tips on painting an intake component? Like I said I did a coolant bypass so I don't think heat will be too much of an issue. Thanks.
Old Jun 8, 2008 | 01:48 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
epoxy paint, comes in a can, they sell it at hardware stores, it wont crack with heat or cold. its super smooth, might even consider painting the inside with it since i wont crack.
Old Jun 11, 2008 | 12:41 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
I cleaned up mine, then used the silver duplicolor engine enamel. it's held up great so far. it matches the color of the powdercoating i had done to the rest of the TPI perfectly. Someday, I'd like to pull the nameplate off and paint it black with silver letters.
Old Jun 11, 2008 | 12:27 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You can get black anondized throttle plates on ebay with Camaro, Z28, etc for about $16.
Old Mar 22, 2009 | 09:10 PM
Dieseltech19's Avatar
Car: 1987 IROC-Z
Engine: 5.7L 350ci L98
Transmission: 700-R4
Axle/Gears: 3.27 Borg and Warner
I know this thread is a bit old but I have painted mine with Duplicolor Primer and paint and have had no problems. Prior to painting I tested the paint's resistance to heat and took heat measurements on the surfaces I planned to paint. The highst reading I got was 175 degrees on the surface of the Valve covers and I heat tested the paint to 250 degrees with no problems. Anyway, here's a pic of my throttle body off the car.
[/IMG][/IMG]
Old Mar 24, 2009 | 04:14 PM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
Nice job on the TB DieselTB. I painted mine as well. I don't have pictures at the moment but in case anyone does a search and wants answers it seems that painting your TB is a great idea and you shouldn't have paint peeling issues or any other issues. I've been running mine for over a year with no paint problems. If you want to have a snazy looking TB and you can't afford a new polished aluminum one get out the spraypaint The only tip I have is its a big waste of time to do all this unless you've done a lot of other cosmetic work under the hood. If not don't bother cause you'll barely notice difference in a typical F-body engine bay
Old Nov 13, 2010 | 09:51 AM
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
how do you guys get the Tuned Port Injection part different colors then the lettering, always wondered that.
Old Nov 13, 2010 | 10:23 AM
Car: 1987 IROC-Z
Pretty easy really. First I cleaned the old paint off everything I could. Then I buffed and polished the raised aluminum lettering. Next I put a few drops of oil on a rag and applied a very thin coat of oil on the raised lettering only. This keeps the paint from sticking to what I had polished. Then I just sprayed the whole things, letters and all, in black paint and allowed it time to dry. Once it is dry you can very easily peel the black paint off the lettering and expose the polished surface with your fingernail. Simple and it looks really nice.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
