what wetsanding process u recommend for this single stage paint?
Old Jun 22, 2008 | 11:24 AM
tripingeorge3's Avatar
i'm out of black single stage and can't buy more due to the fact this is my second gallon of black due to the instruction being wrong on the can. i have 2 coats of color on and basically need to sand smooth so i can apply xtreme clearcoat. i keep reading about which different sandpaper to use , but they don't seem to apply to my screw up. what sandpaper do ya'll recommend for my problem. i have orange peel all over, when i layed my stripes i sanded with 320 for them to stick and didn't go through the paint, but even with 320 it was a pita to get smooth. that was on the hood though. the rest of the body doesn't seem as bad. but here's the pics of my situation and it single stage that i will apply clear over: help please
mm
Old Jun 22, 2008 | 10:15 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: what wetsanding process u recommend for this single stage paint?
Yikes thats pretty bad. You need to wait a few days before you sand.
What exactly was the screw up??? How many coats of clear will you be applying?
Old Jun 23, 2008 | 03:40 AM
as many as i can i guess. i have a gallon of extreme clear. planned on using all of it. it was my first paint job, guess i did't spray wet enough or close enough.
Old Jun 23, 2008 | 08:32 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
How bad is the "orange peel"? Can you feel it on your fingers? If so, i would use 600-700 grit on a block, and lightly go over it until it "smoothes" out.
If you cant feel the grit on your fingers, then use 800 or 850 to scuff the paint, clean it up, and spray the clear. Spray within the flash time of the clear so you dont have to sand in between. And lay on as many coats as you can. You will get about 3 or 4.
Its not worth it to sand the base coat, so alot of people seem to be skipping that step now. If you sand the clear, you shouldnt have to worry about orange peel.
As for the screwup, if you got the paint mixture wrong, it wont last very long and should be redone. If you just got the spray setting wrong, sand paper should fix it.
Old Jun 27, 2008 | 07:02 PM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
i would start with 800 actually. it's too damn easy to sand through with 400-600. Start with 800 at the coursest. Then go over with 1200, then follow up with some polish and a buffer. Glass baby.
sorry and deff clear first
Old Jun 28, 2008 | 04:15 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: wow gold
Originally Posted by stuv024
Ugamegold - UK leader in the provision of. Buy World of Warcraft Gold, WoW Power Leveling and other MMOG Services at Ugamegold.
What the hell is this? I keep seeing this on different websites but what is it? Is it thirdgen related?
Last edited by AmorgetRS; Jun 30, 2008 at 01:42 PM. Reason: Removing the SPAM link
Old Jun 29, 2008 | 10:58 AM
foc400's Avatar
The post is an advertisement for a computer game that is not third gen related.
it should be deleted
Old Jun 30, 2008 | 01:43 PM
AmorgetRS's Avatar
You are 100% correct. If anyone sees posts like this please report them. They are much harder to catch then the normal spam where they post a new thread.
Thanks,
Douglas
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
project89
Sep 24, 2015 06:38 AM
backtothe80s
Sep 5, 2015 12:39 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
