How do you get that SHINE?
Old May 9, 2009 | 11:37 AM
vjw757's Avatar
Car: 92 RS
Engine: 305 TBI
Transmission: AUTO
hey guys my car is pretty shinny. All ive ever used was turtle was and mothers. Id like to see some pics of your shinny wax jobs and what you used to get that shine.
Attached Thumbnails How do you get that SHINE?-1.jpg   How do you get that SHINE?-2.jpg
Old May 9, 2009 | 10:06 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: How do you get that SHINE?
looks good, I use the 3 step meguiars http://www.meguiars.com
paint cleaner, paint polish, paint wax.
clay bar is great for cleaning it up real nicely.
Old May 9, 2009 | 10:18 PM
sccavette's Avatar
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
Zaino, Zaino and more coats of Zaino.
Old May 9, 2009 | 10:40 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
I use this on my GTA. This stuff makes black like a god damn mirror and so smooth you wouldn't Believe. I love this stuff, I probably have about 30 coats of it on my GTA since I got it last august. I highly recommend.
http://www.liquidglass.com/
Old May 10, 2009 | 03:07 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
It's not really the wax that gives you the shine. It's the surface prep. If you want your paint to look it's best, give it a good buffing.
Old May 10, 2009 | 12:35 PM
Samdweezel05's Avatar
I agree. If the surface is not the best to begin with the wax won't do anything for you. If it's real bad you need to start with a heavy cut compound but if you do it too much you will cut through the clear coat or through the color if you have a single stage. If you have never done it befor I would do it by hand as sometimes a good buffer can take it of a little quick and leave you with a bigger mess than you started with. I used 4 steps on this one. It is a really bad single stage paint job that doesn't look too bad after a couple hours with a buffer. It will do for the summer till it gets painted this winter.
Phil
Old May 10, 2009 | 01:32 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
mine does not look that good but even without a clear coat - it looked so bad i just had to repaint it know i was going to do it again later - but do it right - i found that mothers with the block really take the gunk out of the paint and lets it shine up.
makes you feel every inch of the car at the same time.
i cant wait for the engine stuff to be done so i can sand all the waives out of it and paint it right. intend to keep it the original blue it was when i bought it new.
Old May 11, 2009 | 07:13 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
well its kinda hard to see with yellow but she is like a mirror!! wet sanded and polished, looks real good up close, shes not a far away beauty.
Old May 17, 2009 | 10:14 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I use a product called "Race Glaze" Its a breathable poly/acrylic coating.Its a synthetic polish/sealant that you just wipe on and wipe off. No buffing required. You can find it at high end auto parts stores that specialize in performance auto parts/paints. $20.00 FOR 16OZ. It gos a long way.
Old May 18, 2009 | 08:34 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Zaino car polish with Meguairs NXT 2.0 wax. I waxed it OUTSIDE.. In the sun. Didn't miss a spot.
Old May 18, 2009 | 08:41 AM
pascal_91ta's Avatar
Car: 91 Trans AM,Bright Red, T-Top, WS6
Engine: 305 TBI
i use meguiras wax nr 16 and ultimate quick detailer
Old May 18, 2009 | 11:00 AM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
you really have to use a rubbing compound, then a polisher, then a wax to get a sharp, clean, deep shine. i have done this twice. i just did my 08 suburban last night. huge, huge difference. no pun intended. most people don't realize wax is just a sealer. i've had good luck with turtle wax rubbing compound/polisher in liquid form and also 3m. meguiars for the wax. my car was just painted and polished so all i have to do is wax. that's my task for tonight.
Old May 18, 2009 | 06:03 PM
Maladroit's Avatar
Car: I'm looking for a nice IROC
They say (detailers and AutoGeek) that carnauba waxes give a "warmer shine" than straight chemical polymers.
While I'm here to find a nice IROC, (so I don't have a photo), I have tried a lot of waxes and am happy that carnauba wax is making a big comeback after taking a backseat to these advanced coatings.
I won't mislead you, so I have to admit that I sell waxes. But the best I've tried is a German wax called, P21s Carnauba, (about $32) and I don't even sell it!
The problem is, it's very expensive. The secret is to buy S100 motorcycle wax made by the same German company. It's only half the price (about $15) and it is the same wax!
Is it OK to plug my own waxes?
I use Chemical Guys out of CA. They have a polish called Laser Buff that starts out like a compound, but as you buff the particles break apart and become finer and finer, so when you're done, you've actually used a compound and a fine polish. It's pretty cool stuff.
After polishing, I use Butter Wet Wax, which has a ton of carnauba in it, but also polymers and resins, so you get the carnauba "build" and warmth, plus the gloss and endurance of the polymers.
Oh and it smells like bananas too.
Next, whenever I clean it, I use Pro-Detailer spray. Which has carnauba and polymers in it as well. But if you have light surface dust or dirt you can mix it with some distilled water and it works better than a waterless car wash spray.
So the Pro-Detailer renews the carnauba and polymers every time you wash or spray n' wipe your car.
I hope it was Okay to post these links. I'm still kind of new here, but if I wanted info on a TPI, I'd ask a guy here who works on 'em for a living, so I hope it's cool that I offered my .
Old May 19, 2009 | 09:37 AM
Engine: 305 TBI
p21 also has a very good rim cleaner, better then the one from meguiras for me.
Street Lethal
Apr 30, 2019 12:14 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
RacerM
Sep 28, 2015 04:25 PM
neilb
Sep 15, 2015 05:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
