GM HIGH TECH is looking for YOU!!
Car: 1990 TPI Camaro IROC-Z (G92code)
Engine: LB9 5.0 TPI (w/ G92 option)
Transmission: T5 manual 5-speed
Axle/Gears: GU6 option 3.42 posi
Re: GM HIGH TECH is looking for YOU!!
love this formula... I've seen 3 or 4 cars that I think are best so far, and this is one of them. I might need to get in on this...
http://www.associatedcontent.com/vid...rd.html?cat=27
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Bone stock exterior height and factory tips. Every other mod possible. LSX 6.0L
Car: 92 Z28
Engine: Boosted LSX
Looks great matt. hows it going up there? shoot me a email FSTFBDY@GMAIL.COM
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
I'm almost done with mine so I'll put the updated version
Currently the car is apart again for the new engine install and finishing up the engine bay paint work. New engine will be:
ZZ3 350 cu in block with 24cc dish SRP pistons .000"
ZZ3 1053 steel crank
ZZ3 PM Rods
ZZ3/L98 Aluminum heads 58cc, pocket ported, chamber polishing, back-cut valves
Comp Cams 224/224 .537"/.530" - 114 deg sep custom grind hyd roller
Comp Cams 26918 springs
ARP head bolts
Arkansas Polishing TPI intake
Megasquirt II 3.0
Precision Turbo 65 lb/hr injectors
MSD-6AL
700R4 with Pro-Built Automatics Pro-Street build kit
Vigilante 2800 converter
Precision Turbo 60 to 67mm single turbo (replacing current 60mm ebay turbo)
3.27 limited slip 9 bolt rear
100% stock appearance and aound (when not boosting!)
Teaser shot of the new engine!
The last car show before pulling the original 350
The original engine bay before the new engine goes in!
ZZ3 PM Rods
ARP head bolts
Megasquirt II 3.0
MSD-6AL
Car: 1991 Formula 350, 2002 Grand Prix G
Engine: 350 with SLP & Edlebrock mods
Transmission: 4-speed automatic-700 R4
Axle/Gears: 10 bolt with 3:73
My 1991 Formula 350 of which only 1,197 were built. Lots of bolt on items are from SLP/ Edlebrock/ Hotchkis/ Alston/ Hypertech and Borla.
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Mine unfortunatly won't be done till middle of the winter but heres an updated engine pic. Almost done, just need the cold side piping/intercooler and the engine harness.
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Here's my three year project... My 1985 IROC LS376/480 with TVS2300, etc, etc...
https://www.thirdgen.org/forums/ltx-...ne-swap-6.html
1985 IROC Z28 - Near complete teardown and build back up for engine / drivetrain, exterior. interior, etc
Engine / Drivetrain Summary
- LS376 / 480 Crate Engine as base
- Texas Speed Cam, Ported PRC Heads
- Magnason TVS2300 Supercharger with custom fab heat exchanger
- Hawks 2" Primary / 3" Collector Stainless Headers
- Custom Fabricated Exhaust 3" to 4" exit
- Built T56 6 Speed Transmission
- Moser 9" Rear
- BMR Suspension / Subframe Connectors, etc throughout
- GMPP E67 ECM controller, custom tuning by myself and Hutter Performance with HP Tuners
- 566 rwhp /489 rwtq on Hutter's mustang dyno
Exterior Summary
- Disassemble, strip to metal
- Custom Hood with Hawk's Sunoco Style as baseline and then custom crafted to meld in IROC louvers and style
- Rear IROC wheels widen to 9.5"
- High end Black Paint finish to show
Interior Summary
- Complete change out from Red to custom Black with Red Accents
- Custom Lear Siegler "CAMARO" seats / door panels I had Hawks / Acme Auto design for me
- Moser 9" Rear
Exterior Summary
Interior Summary
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
I'll bite...
601hp sbc on e85, t-56, 9" rear, lots lots more.....
check sig for pic
check sig for pic
Engine: 4++,350 & 305 CIs
I dont have a LS swap but here it is... again
Car: 91 TA GTA, 88 Camaro Covnvertible
Engine: TA 350 Supercharged, Camaro 350
Transmission: TA 700R-4, Camaro T5
Axle/Gears: 3.23 Posi in both cars
Blowers make everything better
You'd never know it all fits in this innocent looking bird
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
As cool as that is it must be very hard to change plugs
Car: 02wrx/88 rs
Is it because of the plug location on a gen1 sbc?
Yeah changing plugs on an LS is so easy, no headers obscuring the plug.
Blowers do make everything better, and an intercooler to make changing plugs even easier ahum. Working on this is a PITA, everything goes together so tight, it's literally millimeters between components.
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
Engine: L99 L98
That set up is wierd, that is photoshopped right?
Car: 1986 Trans am
Engine: 5.3 LM7
Pocket can chime in, but the eaton style blowers like that are self contained, meaning they don't necesarily have to be in place of the intake manifold. He made a custom bracket setup that holds the blower and has an intake duct under it which runs into a front mount intercooler and then into the engine. Def a cool setup and probably one of the only times you'll see one mounted like that lol. Thats some fab skills!
Its not photoshopped
I redesigned how it fits, so it becomes a remote mounted unit. I have a build thread in the LTx/LSx forum going into detail how I did it, and the last setup. Same design, smaller blower, smaller engine
Engine: L99 L98
coolest thing I have even seen, that is trick man!!!!
Engine: L99 L98
Car: 1991 Z28
Engine: 5.0L TPI
Transmission: 5 Speed
My 91 Z
5.0L 5 SPEED
MAGNAFLOW EXHAUST
AIR FOIL, K&N FILTERS
ALPINE SOUND 2-12" JL SUBS
BLACKOUT TAILILIGHTS & WINDOWS
5.0L 5 SPEED
MAGNAFLOW EXHAUST
Engine: Cammed 6.0L LSX
Here's something kind of cool. These are the two LS swapped cars me and my dad built (although he sold the coupe just a few months ago after we finished it).
These are more recent anyway...
Convertible engine bay:
Coupe engine bay:
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
1989 Formula 350
355 sbc 370rwhp 340 rwtq, obd2 swap
t56
dana 44 posi with 4.11s
dyno don headers, 3" magnaflow.
http://www.youtube.com/watch?v=5cE1gOF7iLo
t56
Car: 87 Iroc
Hey Nick (BlueZee28) - you can't get in the magazine twice!
For everyone posting up engine bays, we need to see the whole car too or else we can't consider it for readers rides!
Plus it's already been in that magazine twice haha
Car: '91 TA vert
Engine: turboLSx
but but but...the engine bay underside and partial interior is the only thing that looks good on my car...the outside is a dump LOL
Submit it as a project! I'm sure lots of people would enjoy the custom fabwork you do on your car.
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
You've guys with Firebirds did fantastic work....on RUST FREE cars, but my trans needs a medic, exhaust had done broke, the tie rods and gaskets all have issues, and that's just the mechanics, but back in 1998!!??
Check out the archival photos.
http://media.photobucket.com/image/f...indow.jpg?o=75
Selling the car this week, and at worst, someone will buy it just for the TPI engine and scrap the ASC convertible shell?!?
-Bill S.
-Bill S.
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
You know how busy magazine guys are? This is not the place for your questions. Call or email them directly.
Car: 1991 Z28
Engine: 5.0L TPI
HERE;S MY 91 STOCK EXCEPT:
AIR FOIL
K&N AIR FILTERS
POWER CHIP 160+ THOROMSTAT
ROH RIMS 8.5" FRT.9.5" REAR
SUMIT TIRES 245/45/17.FRT. 275/35/17 REAR
DYNAFLOW CATBACK & EXHAUST
ALPINE SOUND SYSTEM W/2-12 JL SUBS
AIR FOIL
K&N AIR FILTERS
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Here's mine.
1991 Z28
LS1 and T56 swap, koni coilvers, brembo 4 pots, much much more.
Build thread: https://www.thirdgen.org/forums/ltx-...8-ls1-t56.html
1991 Z28
Chill on the bickering in this thread.
92 BBC Z - if you read through the thread you'll notice that Justin is not active in it, except to post once and awhile he is looking for cars. I wouldn't expect an answer from him in this thread.
