GM HIGH TECH is looking for YOU!!
Old Feb 19, 2010 | 01:11 AM
  #151
project89's Avatar
Re: GM HIGH TECH is looking for YOU!!
my car may not be the best looking but it sure does perform specially for being a well forgoten about v6 model
the car is powered by a 3.1L v6 making 338Hp and 463Ftlbs @ 9 pounds of boost on pump gas (91 OCTANE) with ignition system issues, car has mild suspension mods and cuts low 1.7 60;s on slicks and mid to low 1.8's on 245/50/r16 street tires not dot slicks or drag radials launching at 3 psi
4k tci super streetfighter converter with 700r4 trans 4:10 gears
megasquirt ecm piggy back with stocker
and the entire car was built for under a 3k budget
and some pics
Old Feb 19, 2010 | 12:06 PM
  #152
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
1989 Pontiac Trans Am GTA
5.7 - 700R4 - T-Tops - WS6 w/65,000 original miles
Modified Tuned Port Injection / Hooker headers / Flowmaster exhaust
Trickflow heads / Comp cam & roller rockers / Procharger/Intercooler
Old Feb 25, 2010 | 09:09 PM
  #153
coolcamaroZ28's Avatar
Car: 95Z / 91Z / 10SS
Engine: LT1 / LB9 / LS3
Transmission: T56 / 700R4 / TR6060
Wow, lots of nice cars! My 3rd gen is just my daily driver, my '95 Z is my show car, and my '10 SS is my baby!
Here's my 91 Z28 - K & N filters, Flowmaster mufflers, Strut tower brace, more here... http://www.coolcamaro.cz28.com/photo4.html
Interior with Hurst Dual-Gate shifter, all new interior and custom stereo...
It was featured in the March '06 issue of the now defunct Camaro World Magazine and would be proud to show it off again in GM High Tech!
Old Feb 26, 2010 | 01:37 AM
  #154
MyFly82Camaro's Avatar
Car: 1982 Camaro SC
Engine: 2.5L 151 cid 90hsp 4cyl
Transmission: 4spd auto
This is my 1982 Camaro SC ( baseline model w/ the 2.5L 4cyl) It's a full restore project at the moment. The engine is out and being rebuilt, the transmission is out being tested and cleaned up. The body needs work and the interior is near flawless. It has 86K original miles and will be showroom new when my team and I are done with it.
Last edited by MyFly82Camaro; Feb 26, 2010 at 01:40 AM. Reason: Couldn't insert picture
Old Feb 26, 2010 | 06:47 PM
  #155
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
1991 chevy camaro, 383 stroker, 6 inch rods, jl pistons,268 comp cam, rpm intake, holley 600cfm,headman headers, vortec heads,hi torque starter,2400 stall,11:1 compression,full msd ignition with msd distributer,holley fuel pump, car is way too fast!!!!!!!
Attached Thumbnails GM HIGH TECH is looking for YOU!!-ernies-new-ride.jpg   GM HIGH TECH is looking for YOU!!-car3.jpg   GM HIGH TECH is looking for YOU!!-ernie-car2.jpg
Old Feb 27, 2010 | 08:14 AM
  #156
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
I don't know if you could consider my car street heat, it's barely luke warm at best but here it is.
Engine, 305 TBI
Mods
Edelbrock intake
CFM ported Throttle body (ultimate TB mods)
TB Spacer
March under drive pulley
Headman headers/y-pipe
Flowmaster cat back
Richmond 3.73 gears with eaton posi and moser axles
Upgraded front/Rear sway bars
BMR subframe connectors
Eibach sportline lowering springs
B&M ripper shifter
Hawks Thridgen sunoco hood and 5 inch spoiler
HP lightning 19X9.5 rims
as with anything else there are plenty of future plans
Old Mar 1, 2010 | 07:12 PM
  #157
Blew-By-You's Avatar
Car: 1992 Camaro "SS Z03"
Engine: 383 Stroker
Transmission: '96 1LE T-56
Axle/Gears: Borg-Warner 9-bolt
Here is my 1992 ZO3 SS which was my first car and I've had for 13 years.
She started out as an RS w/305 + automatic.
Mods: 383 with T-56, GMMG chambered exhaust, 9-bolt + 1le brakes, numerous suspension, C4 17" ZR1 w/ 275 front and 315 rear.
Old Mar 1, 2010 | 07:35 PM
  #158
Engine: 383 Stroker
This is my dads 1992 ZO3 ragtop. Mods include LS1 + T-56, magnaflow, Z hood blisters, SLP ZR1s, tan leather 02 T/A seats.
Old Mar 2, 2010 | 07:32 PM
  #159
johnc9909's Avatar
Car: 1991 Bright Red Formula 350 WS6
No Mods 1991 Formula 305 TPI 17xxx original mile survivor.
Attached Thumbnails GM HIGH TECH is looking for YOU!!-dscf1190.jpg   GM HIGH TECH is looking for YOU!!-dscf1182.jpg   GM HIGH TECH is looking for YOU!!-dscf1191.jpg
Old Mar 2, 2010 | 07:56 PM
  #160
Twin_Turbo's Avatar
How about some of us foreigners?We don't have any resources here at all, 100% self sufficient is the way to do it here. Parts are expensive, not plentiful. Building a nice machine is a struggle, if you go away from stock it becomes even a bigger struggle and more expensive (if I lived in the US I'd be running an LS7w/T56 most likely but here combined they run @ close to 15-20K for used oarts..if you can get it that is)
Would be neat to have a build featured, I have a pro touring supercharged & modded 87 IROC build, buddy of mine has a pro touring supercharged 92 GTA.
Mine
the idea (photoshop pic)
  #161
Twin_Turbo's Avatar
Buddies
Both are a work in progress, the GTA is a good bit further to completion than the IROC but it still needs a bigger brake update.
Old Mar 2, 2010 | 09:27 PM
  #162
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
this is a buddies
TGO user name is: ted gerlach
Old Mar 3, 2010 | 09:51 PM
  #163
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
The guys at GMHTP seem to be a great bunch.
...And guys, they are watching....
http://www.gmhightechperformance.com/index.html
http://www.gmhightechperformance.com...c_z/index.html
Old Mar 15, 2010 | 02:23 PM
  #164
F Bomb's Avatar
Car: 1990 pontiac pro/am 1 firebird
Engine: 305 tbi
Axle/Gears: stock
1990 pontiac pro/am firebird custom body work by ccc all stock drivetrain
this is what im starting with.
Old Mar 15, 2010 | 03:40 PM
  #165
NArtissimus's Avatar
Car: 88 Camaro Sport Coupe
Engine: 01 LS1, Xer-281-hr, 1.75 ProMagnums
Transmission: 4L60E, Stg2, SuperServos, 3200 stl?
Axle/Gears: 10blt, Torsen, 4.10, T/A Gurdle
88 Sport Coupe, Maui Blue. 3.4MPFI w/ 700R4, 4.10 Auburn 4th gen dif, 20" Centerlines at the moment. LS1, 4L60E, 4.10 Torsen and polished C6 wheels to be in a couple of months.
Attached Thumbnails GM HIGH TECH is looking for YOU!!-img_3183.jpg   GM HIGH TECH is looking for YOU!!-img_3779.jpg   GM HIGH TECH is looking for YOU!!-img_3181.jpg
Old Mar 15, 2010 | 05:05 PM
  #166
screeminchicken's Avatar
Another car that needs to post up is Spike-Z.
calling spike-Z
Old Mar 17, 2010 | 11:23 PM
  #167
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Here are some better pictures now that I have it "done", and with a better camera:
Old Mar 18, 2010 | 12:07 PM
  #168
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Info in sig.
Attached Thumbnails GM HIGH TECH is looking for YOU!!-1.jpg   GM HIGH TECH is looking for YOU!!-2.jpg   GM HIGH TECH is looking for YOU!!-3.jpg
Old Mar 25, 2010 | 11:43 AM
  #169
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
1986 IROC
1995 LT1
Lloyd Elliott Heads & Cam
T56 6-speed
4.11 LSD BW 9-bolt
C4HD Font/LS1 Rear Brakes
Best ET/MPH: 12.6 @ 114MPH
Mileage: 230,000 Km
Owned car for 16 years, T56 was installed in 1999, LT1 in 2002
Attached Thumbnails GM HIGH TECH is looking for YOU!!-dscf3674_mod1.jpg   GM HIGH TECH is looking for YOU!!-img_0908.jpg
Old Mar 25, 2010 | 10:00 PM
  #170
lbarile1991's Avatar
-1983 Pontiac Trans Am
-305 H.O V8 Crossfire Injection
-Headman Headers
-Draglite Weld Wheels
Old Mar 27, 2010 | 03:12 PM
  #171
crsr1's Avatar
1991 RS
350 Ramjet
Torque Thrusts
Automatic (700 R4)
Richmond 3:73's
Attached Thumbnails GM HIGH TECH is looking for YOU!!-dsc03964.jpg   GM HIGH TECH is looking for YOU!!-dsc03965.jpg   GM HIGH TECH is looking for YOU!!-dsc03966.jpg
Old Mar 29, 2010 | 09:57 PM
  #172
Steve Petroff's Avatar
Mine
http://www.flickr.com/photos/spetroff/
Old Mar 30, 2010 | 05:16 AM
  #173
pwdbychevy's Avatar
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Originally Posted by Steve Petroff
^We have a winner. Awesome looking car Steve.
Old Mar 30, 2010 | 03:53 PM
  #174
Justin@GMHTP's Avatar
Ok, ok... I know I have been slacking! We have received so many AWESOME submissions that it has been hard to get everyone in. I know some of you have posted on one of the first pages and deserve to get in but at this point I may have just missed you.
So, since it is getting nice out again, lets all break out our cameras and get some new pictures. GMHTP loves supporting our readers, so make sure you post up your ride, even if you don't think you stand a chance. You never know, you may end up in print!
Also, I encourage you to join us on our FACEBOOK and Twitter so we can keep you up to date on what's new in the world of GMHTP. And, off the record, joining our Facebook page may just get you one step closer to ending up in Street Heat (but you didn't hear that from me... )
Old Mar 30, 2010 | 10:16 PM
  #175
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
So can I double dip now that my IRS swap is done? LOL
Old Mar 30, 2010 | 11:46 PM
  #176
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Ok!
here goes my double!!
1988 modified IROC-Z28 383 TPI (to many mods to list)
Old Apr 2, 2010 | 10:33 AM
  #177
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Anyone with a facebook:
http://www.ls1tech.com/forums/multim...your-help.html
Old Apr 4, 2010 | 11:00 AM
  #178
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Old Apr 4, 2010 | 11:28 AM
  #179
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
you are slacking, only one third gen in all of that!
Old Apr 4, 2010 | 12:57 PM
  #180
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
ill have to add mine in. i think i deserve a front page. nah jk . i wish
Old Apr 4, 2010 | 08:33 PM
  #181
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Does anyone know where I can get this months issue? I heard my car made it in the "Street Heat" section. Can anyone verify this? And let me know where to get a copy? I've been to 3 stores and haven't found any GM High Tech Performance magazines.....
Old Apr 5, 2010 | 07:45 AM
  #182
AC's Avatar
AC
Car: Used to drive a camaro
Car is running great, getting closer to the best tune through TunerproRT
Mods can been seen in this thread: https://www.thirdgen.org/forums/cama...-modified.html
Old Apr 5, 2010 | 08:07 PM
  #183
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Here's mines, new TPI going in. 3.73 gears. New Paint. Besides that, mostly stock.
More pictures are here http://s831.photobucket.com/albums/z...a/My%20Camaro/ and I am following on facebook.
Old Apr 6, 2010 | 05:22 PM
  #184
Mark92's Avatar
83 Camaro Z28
383 CID
SLP 1.75 Stainless primaries
Borla 3" Stainless "Cat" back
MSD ignition
Demon Carb
Functioning Ram-Air hood
All Urethane suspension, re-enforced stock suspension components.
Camber-Castor adjustable
Lowered 1.5" from stock
Sub-frame connectors
94 Z28 disc rear end
Dynamat throughout
Enough stereo wattage to drown out the engine if necessary.
Old Apr 7, 2010 | 01:28 AM
  #185
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
you did make it in...i saw it last week sometime when i was thumbing thru one at the store.
Old Apr 10, 2010 | 12:48 PM
  #186
AC's Avatar
AC
Took these last night
LOL, I should probably photochop in the work bench and vise in night pic
Old Apr 15, 2010 | 09:05 AM
  #187
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
my ls1 t56 9" RS camaro
Old Apr 15, 2010 | 09:35 AM
  #188
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
-Headman Headers
Gorgeous. I've never seen any of these cars with their Crossfire Injection system intact.
Old Apr 15, 2010 | 07:08 PM
  #189
revelz's Avatar
Car: 87 iroc 89 pearl white' black 06gto
Engine: 350 Procharged AFR, T76 383 miniram
Transmission: 700r4, 700r4, LS2 t56
Camaro 1989 RS with 92 z28 gfx
383 stroker by Frank Bash engines
Late 350 block one piece rear main seal
Eagle forged stroker kit with:
4340 forged H-beam connecting rods 5.7
SRP dished forged pistons
Eagle 4340 crank 3.750
Dart heads Pro 1 aluminum
215 intake runners, 64cc, 2.05/1.60
Crower high rev kit
Crower solid roller cam #00426
Lift .57/.584 duration 288/290degrees lobe separation 112 degrees
Competition cams 1.5 roller rockers
Moroso stroker oil pan
Miniram intake manifold with fuel rail kit
BBK 58MM Throttle body
Flex a lite dual fans
160 tstat
T76 turbonetics turbo, turbonetics raptor bov, turbonetics wastegate evolution.
BBS design turbo header
Mufflex Ypipe
Mufflex 4inch catback with spintech muffler
Air Ride front and rear Cool Ride kit
This are some of the mods on my car. Too much to list. Additional photos and the list on cardomain http://www.cardomain.com/ride/373298
Jimmy
Attached Thumbnails GM HIGH TECH is looking for YOU!!-dsc00910.jpg   GM HIGH TECH is looking for YOU!!-3732980053_large.jpg   GM HIGH TECH is looking for YOU!!-dsc00013.jpg
Old Apr 18, 2010 | 10:22 PM
  #190
MNformula350's Avatar
1990 Pontiac Firebird Formula
Abbreviated Mod List:
Modified 89 350 TPI, 4L60E Auto Trans, 3:73 Posi Rear
Aftermarket Suspension Mods for Auto-X and Road Racing, Custom Interior, 84 Firebird Front & Rear Bumper Covers
Old Apr 22, 2010 | 04:37 PM
  #191
IrocZ74's Avatar
Car: 1989 IrocZ28 Camaro
Engine: 5.7 V8 L98
Axle/Gears: 2.77 posi
89 Irocz28
5.7 V8 auto
no engine mods yet
restored in about 6 months
Old Apr 22, 2010 | 07:39 PM
  #192
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
1992 Z28 Coupe, 350TPI, Headers, 1.6 rockers, ported intake, 24lb injectors, intrax springs, tokico shocks & struts, hotchkis sub frames, LCA's, 18x9.5 Zo6's, full exhaust, tinted tails, custom ghost purple heritage stripes.
Pictures are before the intrax springs and tinted taillights:
Hopefully i'll get some updated pictures this month.
Old Apr 29, 2010 | 02:49 PM
  #193
ezss's Avatar
I must admit I have never seen so many pretty third gens in one place!
"Project Red": 1989 Camaro RS 305, original motor, bolt-ons, full suspension (shocks+struts/springs/subframes/lower control arms/sway bars/steering brace/trans bushing, etc..), ROH Snyper rims (17s with 275 tires), 95% restored from rusted out (have pics of this as well if desired)
In one pic, my 4th gen SS, with a 402cid LS2 (10.9s@125 pump gas/full weight)
Attached Thumbnails GM HIGH TECH is looking for YOU!!-red3gorg3.jpg   GM HIGH TECH is looking for YOU!!-red3gorg1.jpg   GM HIGH TECH is looking for YOU!!-red3gorg2.jpg
Old Apr 29, 2010 | 07:47 PM
  #194
sjgrimsley's Avatar
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
In love with the red one.
Old Apr 30, 2010 | 01:23 PM
  #195
carbonday's Avatar
1991 Fully Stock all options v8 runs like a charm
Attached Thumbnails GM HIGH TECH is looking for YOU!!-front.jpg   GM HIGH TECH is looking for YOU!!-sidetopdown.jpg   GM HIGH TECH is looking for YOU!!-sidetopup.jpg
Old May 1, 2010 | 12:11 PM
  #196
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
1991 Camaro RS
305 TBI
headers, perform chip, cold air intake, a/c delete
flowmaster exaust
5 spd (stock)
4.10 posi disc rear
aluminum drive shaft
Iroc front/rear sway bars
Hugger Orange Paint
Iroc Hood
Custom Klerz Tailights
Grey /Black interior w 97 camaro seats
17 chrome irocs
crossdrilled/slotted rotors
UMI crossmember, wonder bar, caster camber
GR2 struts and shocks
Edlebrock strut tower brace
poly bushings in suspension
summit racing lowering springs
TPI conversion coming this summer, along with brake upgrade and t-56 conversion. Im currently overseas in Afghanistan mentoring and training police, so i look forward to returning home to start the new modifications
Old May 3, 2010 | 05:49 PM
  #197
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
http://www.gmhightechperformance.com...c_formula.html
http://www.youtube.com/watch?v=IdSEFJJlwKU
Old May 5, 2010 | 09:03 PM
  #198
fandreou's Avatar
1991 Camaro optioned with the 1LE package with 1,100 Original Miles
Van Nays built car, the last year Camaros were built in Van Nays, Ca.
Purchased from City Chevrolet in San Diego, CA in November of 1990 and never Dealer prepped.
With all Six options that were available:
Gray Leather
Radio – AM/FM CD player
Electric Door Locks
Rear Sun Shade
Rear Window Defroster
Block Heater
Yes, it's bone stock!
Attached Thumbnails GM HIGH TECH is looking for YOU!!-camera-060108-220.jpg   GM HIGH TECH is looking for YOU!!-camera-060108-221.jpg   GM HIGH TECH is looking for YOU!!-camera-060108-222.jpg
Old May 6, 2010 | 09:24 AM
  #199
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Gray Leather
Electric Door Locks
Rear Sun Shade
Block Heater
I hate to rain on anyone's parade... Buuut... 1992 was the last year for Van Nuys Camaros. You appear to have an awesome car however...
John
Old May 6, 2010 | 09:05 PM
  #200
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
82 Z/28
- 355 4 bolt roller ~475hp
- 92 GFX + seats
- doug nash T5 conversion
- shorty headers w/ electric cutouts
Attached Thumbnails GM HIGH TECH is looking for YOU!!-img_0041.jpg   GM HIGH TECH is looking for YOU!!-camaro.jpg   GM HIGH TECH is looking for YOU!!-camaro3.jpg
