post pics of shaved or smooth engine bays.
Re: post pics of shaved or smooth engine bays.
And the washer tank you can run under the dash and drill a hole in the frame to run your starter wires straight over and then all your headlight wires you run through the opening where your bumper brace mounts up. Also you can go as far as converting to will wood pedals and run everything inboard for your brake and clutch resivour
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Almost there, actually after pictures, I put the plugs in and am getting ready for power steering hose, radiator hose, etc... All the little stuff. Also got the scanner cover on and test fitted. Glad it all still fits good... Never seen it with the real engine bay... Turned out cool.... Anyway... All Turbo stuff is done also... Waiting on downpipe to get coated, after that, it's done... and will be only needing little stuff. Excited. Will be by the end of the year cranked and outside looking like KITT for sure. Very close!!
Terrell351
Jun 13, 2021 01:13 PM
Linson
Aug 21, 2015 02:12 PM
