how did u clean your tanks?
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I was doing some cleaning under the hood hiding wires and what not but the dirty washer and overflow tanks just stand out with the new paint and what nots. What did you do to clean yours.
Re: how did u clean your tanks?
buy new ones
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
outside of tanks no problem , inside not so easy . a method i have used with good results . don't laugh , "LIQUID PLUMBER GEL" . remove tanks , flush & rinse . wrap a few old nuts & bolts in a rag , secure them in rag & insert in tank , plug/cap all openings , pour in liquid plumber . slosh around all sides , let sit 15-20 mins. on each side , slosh around again . use liquid plumber full strength (use care , you can get burned) , rinse & repeat as needed . final step , remove rag , wash & rinse inside with soap & water . "DON'T LAUGH" , it DOES work . good luck .
COTM Editor
^^^ This is pretty close to what I used when cleaning the overflow bottle on my vert.
I used brake FLUID on the exterior to clean the plastic with really good results, but I removed the tank and soaked in a large tub with mixture of bleach, water, and some toilet bowl cleaner with bleach (I'm no chemist, so mix your chems carefully). I left my tank completely submerged for almost 48 hours, and it cleaned it really well.
Before:
After:
My washer tank I only cleaned the exterior using brake FLUID and a small scrub brush covered with a rag to prevent splatter of the BF.
Before:
After:
Before:
After:
Before:
After:
I tried the toilet bowl cleaner and bleach thing. I bought the wrong toilet bowl cleaner and wound up with some kind of reaction going on - good thing I had it outside because it might have turned into a hazmat incident. Anyway - I got them clean, but not perfect. i think a nest coolant tank is on my needed list. I will have to live with my washer fluid tank, as that one is unobtainable unless I settle for something that doesn't look correct.
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
The 82-87 washer reservoir is incorrect for the early third gens. There was a second design. It will work but will not look correct.
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Before:
After:
Before:
After:
Before:
After:
Before:
After:
COTM Editor
Looks great? How the hell do you get the bolt off for the overflow that goes to the strut tower, you know the one that is a 10mm that is behide the wheel well liner? I tried for 15 mins at the junk yard and the whole shaft just spun-did not see a way to get a tool inside the bottle.
COTM Editor
Thanks. I haven't ever really heard of it either. I used it to remove paint from a plastic part years ago, and hadn't really tried to test it capabilities until I got the messy vert. Figured if it would remove paint it could remove other random crud on plastic. I used it in various underhood areas with awesome results, pics in my thread for the vert.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Good job,looks great.I want to ask you if the windshield washer bottle you have, is it for a cruise control model ???
COTM Editor
Car: Faster
Engine: Than
Transmission: You!
Remove tanks, cap bottom hole, fill half way with a bleach solution (75% bleach / 25% water), cap top hole, shake the crap out of it until clean. Spray same solution on exterior of tanks and let soak for 30 minutes (keep it wet with solution). Rinse tanks inside out with water. They will look great!
Engine: 5.0 EFI
this bottle is off a 87 TA,I've replaced it with an original one,witch by the way,was so hard to find.
COTM Editor
Our washer bottle look to be the same. You just have your battery mounted where the cruise is mounted, and gets moved up to the fender - Firebird.
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
If you breathe any of it in you will have a VERY bad day!
Engine: 4++,350 & 305 CIs
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
This is how to take off a thirdgen overflow tank:
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Before:
After:
Before:
After:
Before:
After:
Before:
After:
Holy crap, how did you clean everything else? Your air box, plenum, etc all look spotless! How did you do that? I need to clean up my engine bay something fierce.
COTM Editor
https://www.thirdgen.org/forums/conv...le-92-z03.html
Car: '97 TA WS6 vert & '88 Formula 350
Engine: LT1 & 383 HSR
Transmission: T-56 & T-56
Axle/Gears: 3.42 & 3.27
Nice work. My tanks are the biggest eyesore in my engine bay. I have been contemplating a way to hide them so I don't have to look at 'em!
Bohemian
Aug 15, 2017 05:11 PM
Glowsock
Sep 5, 2015 07:48 PM
