headlight covers
Old 09-04-2014, 07:02 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
headlight covers
awhile back I seen headlight covers that went over the headlights themselves and not the opening. now I cant find them. anybody kno where I can find them?
Old 09-04-2014, 05:08 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: headlight covers
I think GTS used to make the covers you're thinking about.
I used to run some GTS covers that just snapped over the glass on my '87 Legend. I ran these from when the car was new up until a few years ago. They finally got so dinged up, sand blasted and brittle that I had to pitch them. I now use that clear, thick 3M protective film on them.
The only other ones that I recall are some off-brand plastic covers that mount in between the sealed beam housing and the retaining ring. But this was a l-o-n-g time ago. I had these covering my Cibie lamps on my '74 Camaro.
The only covers I see now are those steel mesh ones the 4x4 crowd uses.
Edit: I'm referring to clear covers that are more for protection than looks.
Old 09-05-2014, 07:20 AM
Engine: 355
ya I looked everywhere
Old 09-05-2014, 07:54 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Try ordering a set for a 91 full size chevy truck. I had a friend that used the ones off his dads truck back in the day. They clip onto the lamps. Plus when you order a set, it has 4 so you have extras if you loose one.
Old 09-05-2014, 10:17 AM
Engine: 355
they single 4x6 lamp covers?
Old 09-08-2014, 10:06 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Looks like they changed them in 91. You need the covers that fit the 1988 truck. It has double headlights up top. Both Hi and Lo beams. The cover only fits over the headlights and not the marker lights. So the headlight bucket will not be covered, just the lights.
Old 09-08-2014, 10:22 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Whatcha can do is what I done on my 79 T/A back in the day.......Take and cut 1/8" Plexiglas and cut to fit the lights and paint the backs flat black and attach velcro tabs in each corner of the lights.....It looks good......but you have to remove them for night driving.
THAT was a veeerrry looooong time ago!
Old 09-30-2014, 08:40 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I was just about to post a thread about some headlight covers I found in my parts bin. I received them with the car back in the day, but never used them. Im interested now. Anyone know anything about these ?
The clear ones look as though they would fit with some velcro'd side mounts, but the black ones I cannot figure out. They look as though they were intended for the IROC, but they are too big. Those are by AVS, cant find any info on the part numbers though.
Old 10-02-2014, 03:38 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
The smoked ones fit early 82 style camaros
Veaceonee
09-29-2016 08:15 PM
1Aauto
Sponsored Vendors
10-05-2015 03:14 PM
Isaac McCormick
09-12-2015 10:20 PM
sylentnite
09-09-2015 02:55 PM
luvofjah
09-03-2015 07:08 PM
Quick Reply: headlight covers
