sunvisors???
Old Oct 31, 2002 | 12:34 AM
Kandied91z's Avatar
sunvisors???
are there any cars out there that you can swap sunvivsors to get rid of the old ones that have trouble staying up?
i've tried 4thgens, but the mounting bracket is shaped differently?
any suggestions.
Old Oct 31, 2002 | 01:38 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I ended up just buying some new ones from Year One. No more floppy floppy
-Schultzy
Old Oct 31, 2002 | 07:05 AM
fly351's Avatar
Car: 1996 Camaro RS
Engine: v6
i had thought about making my own out of plexy-glass, putting 0% tint on one side, and silver tint on the other side that fades into black tint on the edges, hence making a mirror. and since plexy-glass can be drilled through easy without breaking, mounting it would be easy.
-fly
Old Oct 31, 2002 | 09:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
It's been my experience that the 'flop' is caused by the hanger. The 'bullet shaped' piece that inserts into the visor itself breaks free of its housing and as a consequence, freely rotates--which means that regardless of how much the visor screw is tightened, 'flop' will occur. New hangers from a boneyard are inexpensive.
JamesC
Old Oct 31, 2002 | 10:53 AM
uk89camaro's Avatar
self adhesive velcro pads....
Old Oct 31, 2002 | 11:02 AM
JamesC's Avatar
UK,
Strangely enough, my car had the Velcro fix when I came into possession. I think that, in part, started the separation of the cloth from my headliner.
JamesC
Old Oct 31, 2002 | 11:24 AM
FLYNLOW92rs's Avatar
Just buy new ones.........
That should solve the problem....
Old Oct 31, 2002 | 02:03 PM
Kandied91z's Avatar
no.1 i don't like the stock ones........they are rather flimsy and don't have any accessories either.
no.2 most yards that have them are suffering from the same extent.
it isn't that they are even that bad; i just want them to look better. i've tried tightening them up and that must be the reason. anyone know how to get the hanger itself apart from the visor without ripping it apart?
has anyone installed visors other than 3rdgen?
Old Oct 31, 2002 | 02:49 PM
JamesC's Avatar
After loosening the screw, the visor should simply slip off the hanger. Aside from a mirror, what accessories are available?
JamesC
Old Oct 31, 2002 | 03:21 PM
uk89camaro's Avatar
Originally posted by JamesC
UK,
JamesC
James,
I've just replaced my headliner, brought down big style by a 100mph blast with the windows down in summer... If your headliners ready to go, it'll go with, or without velcro.
Old Oct 31, 2002 | 03:37 PM
JamesC's Avatar
Uk,
New headliner, new visors, new hangers, so I'll forgo the Velcro; nevertheless, I just might try the 100 mph blast you spoke of!
JamesC
Old Oct 31, 2002 | 06:24 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
I know this might sound lame, but I wrapped that bullet shaped rod with electrical tape(not too much, just enough so the visor would still fit) and screwed the visor back on.
I also switched my original ones with 92 Firebird visors..they have a cover for the mirror so you don't have to be distracted by your reflection every time you need to block the sun.
Old Nov 1, 2002 | 05:34 AM
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
visors are no more, hanger faces outward
my visors look something like these...
Old Nov 1, 2002 | 06:23 AM
ausrs's Avatar
the fix for droopy sunvisors is extremely simple
where the alloy "bullet " shape breaks away from the steel rod drill a small hole all the way through both pieces and pin it with a nail or whatever ,i did mine around 3 years ago and they havent drooped since
btw when finished file carefully and re paint gloss black
hope this helps someone out !
Old Nov 1, 2002 | 03:07 PM
ohohblita's Avatar
when i recovered my headliner i just covered over the holes for the visors, and ditched them. like it a lot better that way.
Old Nov 1, 2002 | 03:33 PM
Keith27's Avatar
Ok here is your 4.99 fix. This what I did and it works fine.
There is a screw that can be tightened, after some years it gets worn out. Take the screw out and slide the visor out and you'll see the slot that the screw rides in. Get some JB weld and build up the slot just a little, let set for a few hours and reinstall.
Did this over 3 years ago and still works great.
Peace
Old Nov 1, 2002 | 03:55 PM
Saywhut's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=133126
Veaceonee
Sep 29, 2016 08:15 PM
camarosource
May 27, 2004 01:07 AM
srcamaro
May 14, 2004 02:00 PM
MYROC19
Oct 19, 2000 03:46 AM
