Unstable speedo
Old Dec 23, 2002 | 02:16 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Unstable speedo
Whassup with my speedo? it quivers and jumps around a bit as I drive down the road at a constant speed. The tach is nice and stable but the speedo trimbles like it has a chill. Is this thing getting ready to fail? Bad speedo? Bad cable? Bad gears in the tranny?
Thanks.
Old Dec 23, 2002 | 02:35 PM
bradkeith's Avatar
mechanical speedo right? Your problems could be due to a lack of lubrication in the cable assembly. Does your speedometer sqeak and chatter also? I've found that graphite works best on the speedo cables.
Old Dec 23, 2002 | 03:07 PM
Tremo's Avatar
Yes, mechanical speedo. It does not (as of now) make any noises.
How does one go about lubing the speedo cable? Thanks.
Old Dec 23, 2002 | 04:45 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Pull the cluster out, then pull the cable out of the housing. Graphite or wite lithium grease is what I found to work best. If lubing the cable dosent smooth it out, check the gears in the trans that run the speedo. The teeth could be broken or chipped causing your needle to bounce.
Old Dec 23, 2002 | 07:20 PM
bradkeith's Avatar
t-top hit it on the spot. I do believe that the graphite is easier to get down the length of the cable, as white lithium is fairly thick.
LOL, never squeeze the graphite tube while the top is off though
Old Dec 23, 2002 | 07:43 PM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
Tremo said that his jumps around. What about one that doesn't even register untill you hit around 25 mph or so, and then ever so smoothly goes to about 70 even though you're only doing about 50?
Old Dec 23, 2002 | 10:39 PM
bradkeith's Avatar
hmmm? that would lead me to believe that something inside the speedometer was messed up. maybe a weight on the inside fell off?
Old Dec 23, 2002 | 10:43 PM
Engine: 305 TBI
Yeah, I was thinkin that it was probably in the gauge itself. It was like that when I got the car, so I'm kinda used to it. Besides, I drive with my tach anyway.
Old Dec 23, 2002 | 11:09 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
My speedo has completly failed on me!! But what could have caused it?? I checked where the speedo hooks up to the tranny and it all looks good?? WHATS THE DEAL??
Driving without it is kinda fun though
Old Dec 26, 2002 | 10:52 PM
Black86IROC-Z's Avatar
Mine jumps just a little at around 35, and then it goes completely nuts around 100-105, to the point that I have no idea how fast I'm going (not that it really matters at 105 ) Any idea what would be causing this? It's not squeaking at all, my old one did that. I don't know that it'd be something to do with the cable, my first thought is that something slips in the transmission. Any thoughts?
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
