Defrost always on... Please help
Old Mar 20, 2003 | 01:44 PM
86pinkiroc's Avatar
If I turn the heater or A/C on, I get the air blowing out of the defrost vents... never out of the other vents.. Is this a vacuum leak somewhere? I thought it was my heater control, so I bought one off ebay, but that cable was a bear and I didn't see anything broke on my old one. I did notice a large plug with a bunch of vacuum lines on it... Where the heck do these go?? Any help would be greatly appreciated. Thanks!
Old Mar 20, 2003 | 01:49 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Probably a vacuum Leak like you thought, Mine was under the hood pu by the firewall, there was a little check valve close to the center of the car by the heater box...
Hope thats it... (should make your car run slightly better too..)
John
Old Mar 20, 2003 | 02:20 PM
gmanuel's Avatar
The selection of which vent the air comes out of is controled by vacuum. If you hear a vacuum leak in the car then I would first check the control that you use to select vent heat etc. If you move the **** slowly you should hear the doors that deflect the air, open and close. yes you should have the car running . This **** has the all those vacuum lines on the back as you saw. There is a plate in behind the white thing that the lines connect to that directs the vacuum. I have found that this becomes worn and lose. You can try to press it together again or get a new one from the dealer.
Old Mar 20, 2003 | 02:49 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The default location for air flow is the defroster vents. If there is vacuum leak that doesn't allow the actuators to change the air flow, it defaults to defrost. Check all vacuum lines that connect to the controller. My wife's 93 Z28 had the same problem and I found the main vacuum line fell off the charcoal canister. We had other issues also, like on a long trip, the brakes would lose pressure and she needed to pump the brakes to rebuild the vacuum. City driving was OK since the brakes were used regularly, but the long drive home, with the AC blowing out the defroster vents only and the brakes acting up, my wife was ready to sell the car!
Old Mar 20, 2003 | 02:57 PM
okfoz's Avatar
A Bad Master Cylender Would do the same thing...
John
Old Mar 20, 2003 | 05:21 PM
86pinkiroc's Avatar
Thanks for all the help.. Will check it out this weekend while I change the door handle... Also I have the only PINK camaro on here.. that could be good and bad.. lol
Old Mar 20, 2003 | 06:29 PM
scottmoyer's Avatar
John
I was thinking that at the time, but the problem was solved after I reattached the main vacuum connection. It was the cheapest repair I've done to a car in a long time. I even called and got estimates on a master cylinder before I found the vacuum problem.
Old Mar 22, 2003 | 11:21 AM
86pinkiroc's Avatar
Well I did some work on this vacuum leak today.. I found a little round thing that goes through the firewall right above the master cylinder and below the canister... It was not connected and was actually broke in half.. That piece goes into a T where 1 goes to the wiper pump (which it runs, but no fluid comes out) and the other looks like it goes over on the passenger side into the firewall? I don't have any vacuum anywhere in these lines... don't know what to do from here..
Old Mar 23, 2003 | 07:53 AM
gmanuel's Avatar
What you have found is the windshield washer lines. If one is broken then that is why your washer does not work. There is a black vacuum reserve that is near where you are looking that has a vacuum line from the intake manifold going to it. then the outlet of the reserve goes over to the passenger side of the firewall and into the interior. Do you have a vacuum pump? To test the vacuum lines in the interior get a pump and create vacuum on the line from the reserve. (You can try sucking on the line) If there is no vacuum move the vent selection control on the heater control to see if one position can give you vacuum. If not then you have to get at the heater control and see if a vacuum line has fallen off of if the control value is not sealing.
Old Mar 24, 2003 | 06:23 AM
86pinkiroc's Avatar
Thanks! I will give that a try this weekend.. I have a vacuum pump... I did find that black canister that you mentioned. It was mounted on the firewall right above the master cylinder/booster.. I did have good vacuum there. Thanks again for your help.
Old Mar 24, 2003 | 10:22 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I believe that even with everything turned off, there will be a minimal airflow through the defrosters. This is done to maintain positive cabin pressure to help keep exhaust fumes out.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
whibbs
Exterior Parts for Sale
Sep 28, 2015 07:53 PM
scottmoyer
Sep 7, 2015 07:06 PM
SlowAZ28
Members Camaros
Aug 31, 2015 07:53 PM
3rdgenparts
Aug 8, 2015 11:48 AM
