Can this be bumped out?
Old Oct 13, 2003 | 05:00 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I am wondering if this can be bumped out or do I have to get a whole new fender? The dent is no bigger then the size of a finger and its not deep. And the bumper can be buffed out I think. Detail people....what do u think?
Old Oct 13, 2003 | 05:12 PM
TMoNeE's Avatar
Car: 87 Z28
good job eric u damn loser
Old Oct 13, 2003 | 05:15 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Tim, get off my thread. lol.
Old Oct 13, 2003 | 05:19 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Well from what I can see in your picture...which isn't much. Yes the bumper does appear that it can be buffed out, as long as no paint has been removed or deply scratched that is. As for the fender, it most likely can be straightened out if done carefully. But the paint may crack or peel even when doing this. What did you hit, or what hit you??? This may help understanding the damage a bit better. It looks like the marks are from a tire hitting it??
Old Oct 13, 2003 | 05:57 PM
LUVmy92's Avatar
Car: Camaro
You should be able to with a good polish , I ahve done it before but not to that extent.
Old Oct 13, 2003 | 06:32 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Someone hit me in a parking lot when I wasn't around and they drove off.
Old Oct 13, 2003 | 06:52 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
You have to hate jacka$$es who do that to ya!! So does it appear to be caused by just a tire, or is that black paint??
Old Oct 13, 2003 | 06:57 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I think it was both maybe. Not sure. But it was enough to dent the fender where it meets the bumper by the width of my finger.
Old Oct 13, 2003 | 07:09 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
some mild rubbing compound sould do the trick, unless the paint has actualy been chipped, then you'll have to repaint (or touch it up for now).
bummer man, that sucks
Old Oct 13, 2003 | 07:21 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Well a tire alone can cause a lot of damage all on it's own. Well, like both myself and Error404 mentioned, as long as there are not any deep sctaches or chipping or peeling. You should be able to buff it out, or at least most of it. As for the dent... I would probably try to buff the marks off some first before trying to straighten out the fender. If the fender has any big scratches or chipped paint it will require paint and some minor body work anyway.
Old Oct 13, 2003 | 07:55 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
wow the same thing happened to my 91 in the school parking garage last year except on the drivers side and it didn't dent the metal but i was able to buff out most of the nose with a buffer and some polish
Old Oct 13, 2003 | 08:58 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Body related goes to the Body forum
Old Oct 14, 2003 | 10:55 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Sorry, didn't know there was a body forum. Thanks
As for the buffing, I will try that out on the bumper. But paint has chipped on the fender where the dent is at.
Old Oct 14, 2003 | 11:02 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If the paint was chipped down to the metal, put some kind of paint on it fast! The dent can probably be hammered out; since the fender's trashed already, give it a try. You might be able to reach the area from the back just by removing the inner plastic fender. Note the plastic rivets that hold the plastic inner fender to the metal outer fender- pull the center up with pliers, it'll pull up about 1/4 inch, then you can pull the rivet out with your fingers (or pry it up with a screwdriver if it's being difficult).
Practice first on a spare piece of sheet metal. You can buy sheet metal at Home Depot in their hardware aisle, a small sheet is $5. Buy a body hammer and a "heel dolly"- a flat dolly shaped like the heel of a shoe. Kick the sheet metal a few times, then practice with the hammer & dolly on it.
The big difference is, the sheetmetal won't support itself while you ding. Your fender has a shape to it, and it won't flop around while you're using the hammer/dolly on it. Try to leave the fender on the car while you work on it; it'll add extra support. You don't want to try to work a hammer & dolly while you also try to keep the fender from moving on the garage floor.
If it works out "close" but not perfect, a skim coat of Bondo is perfectly okay. Keep the thickness to an absolute minimum- max should be 1/8th inch... and that's almost too thick. The bad Bondo jobs are people just slapping 1/4 inch of filler into a huge dent. Metal should be sanded with 40 grit to give the bondo good "tooth" or "bite". And bondo, and most spray-can primers, are not waterproof! So don't leave bare bondo, or bare primer, on the car. Topcoat it with something.
Old Oct 14, 2003 | 12:27 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Thanks A LOT tom. I appreciate the help. Do you think some touch up paint on the bare metal is fine for atleast a couple weeks?
Old Oct 14, 2003 | 06:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
No problem! Touch up would be cool; but it might not stick to bare metal. You might need some primer first. Your local parts store might have a book on bodywork, too... it's worth the $15.
Old Oct 14, 2003 | 10:48 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
You mentioned that the dent isn't major. Contact a reputable dent removal company and see what they'll charge. Ask the tech if he's willing to do it after work hours to save you some $$ and make some $$ for him.
Old Oct 15, 2003 | 10:09 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Yeah, I talked to my uncle who repairs wrecked cars and he pointed me in the direction of a good guy who would take the dent out and said for any of the other imperfections to put a VERY think lair of bondo on it. He said the black marks could be buffed out and if they are any deep scratches to do the same thing that I did with the dent. He said this guy would probably only charge me 200 bucks, compared to the 1278 bucks from the other shop. I will put before and after pics when its repaired.
gta892000
Aug 11, 2019 11:16 AM
Elephantismo
Feb 13, 2019 12:51 AM
Ed1LE
Sep 30, 2018 09:14 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
Chiknhawk
Sep 10, 2015 08:55 AM
