roll cages/bars
Old Feb 23, 2004 | 10:03 AM
AFTERMIDNIGHT's Avatar
Car: 1989 Camaro, 2008 600RR
Engine: 311
Transmission: T-10
Axle/Gears: 02 SS Rear with 3.23 Gears
roll cages/bars
i would really like to see pics of the comp engineering cage kit installed. if anyone has pics of caged f-bodies, please, please post them. really in a bind and i need to see which cage you all think is best for tight fitment and safety. thanks a million!!!!! pat
Old Feb 23, 2004 | 10:31 AM
JBert's Avatar
Car: Looking
Pat, i suggest you go with S&W Racecars. They make custom door bars that bend to the curvatures of the arm rests on the doors. Im ordering my kit thru them, and have heard nothing but good things about them.
Old Feb 23, 2004 | 10:33 AM
Engine: 311
Transmission: T-10
do you have a link for them? thanks, pat
Old Feb 23, 2004 | 03:19 PM
Engine: 311
Transmission: T-10
i went to their site, i would really like to see some pics of it and others. thank you all very much, pat
Old Feb 23, 2004 | 06:50 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
Transmission: fairbanks turbo350
heres some of the comp enginering rollbar 8point
Attached Thumbnails roll cages/bars-rollbar7.jpg
Old Feb 23, 2004 | 06:51 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
Attached Thumbnails roll cages/bars-rollbar6.jpg
Old Feb 23, 2004 | 06:54 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
Attached Thumbnails roll cages/bars-rollbar1.jpg
Old Feb 23, 2004 | 06:56 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
4 i made my own door handles,they work good.
Attached Thumbnails roll cages/bars-p5230012.jpg
Old Feb 23, 2004 | 07:04 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
my door bars are tied to my frame connectors in the front. thats the best way to do it.
Attached Thumbnails roll cages/bars-doorbar.jpg
Old Feb 23, 2004 | 07:38 PM
MCas7's Avatar
As soon as I take the rest of my interior out, I will be having an S&W 8 point installed. I will be taking a ton of pictures and posting them on my website. I'll post when I get them all up.
Old Feb 23, 2004 | 09:03 PM
MizfitCreations's Avatar
Car: 87 Camaro LT
Engine: ZZ4, AFR195, XR276-HR
Transmission: 700R4, Transgo
Here's a pic of the S&W cage. If you can get 3 people to order they will give you a group discount. Also, they had very excelent customer service. Talk to Stokes 800-523-3353 ext 15
Old Feb 24, 2004 | 11:38 AM
Engine: 311
Transmission: T-10
nice job fellas! pat
Old Mar 7, 2004 | 07:06 PM
BOTTLEDZ28's Avatar
Transmission: A4
C U Later, are you using the interior in your car? I ask because it looks like the hoop will interfere with the plastic panels and maybe the rear seat. You have the hoop welded a bit further back then I do on mine. I tacked mine one step lower toward the front of the car, maybe 3 in" more then yours.
Old Mar 8, 2004 | 08:24 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
yes the interior is in my car. i had to trim the sid panels just a little to get it to fit. i test fitted the panels before i welded the bar's. i put the mainhoop a 1/2" from the side for a nice tight fit,and the top of the hoop is 1 1/4" from the roof,that puts it 1/4" from the headliner. if you put the mainhoop forword it will reduce your seat adjustability when you add the crossbar. i just followed the NHRA rule book and got advice on bar placement from other racers. heres a another pic. i almost forgot, i didnt put the rear seat back in. i didn't want more then one passinger.
Old Mar 14, 2004 | 04:59 PM
BOTTLEDZ28's Avatar
Transmission: A4
Does anyone have a pic of the S&W side door bars for our cars? How many bends are in them. My C.E. bars dont fit with the stock arm rest
Old Mar 14, 2004 | 05:16 PM
Kandied91z's Avatar
i have yet to see a prefabbed cage that isn't visible from the side...one of the reasons why i had mine made. that and most seem to be a pita to get in and out of the car.
Old Mar 14, 2004 | 05:34 PM
BOTTLEDZ28's Avatar
Transmission: A4
I know what yo umean about it being hard to get in and out. I put the drivers door bar in place and tried getting in and out and boy was it a lot harder then I thought. If I chose NOT to put the doors bars in, then what is the quickest I will be able to run leagally at the track. I want the bars there for strength so I might try and make it like the Kenny Brown street cage.
Kandid, do yo uhave any pics of your cage?
Old Mar 14, 2004 | 05:46 PM
Kandied91z's Avatar
mine may not be as legal as the straight side bar but for what i do at the track on test and tunes and club nights its just fine for running as fast as a 6pt. can.
here are some pics.
Attached Thumbnails roll cages/bars-corbeau-cage-trailer.jpg
Old Mar 14, 2004 | 05:47 PM
Kandied91z's Avatar
Attached Thumbnails roll cages/bars-kandied-dreams-rear-side
Old Mar 14, 2004 | 05:48 PM
Kandied91z's Avatar
...so easy to get in and out and i can't notice the cage for the most part beyond obvious reasons. i really love how it fits and works for my needs.
Attached Thumbnails roll cages/bars-kandied-dreams-interior-small.jpg
Old Mar 14, 2004 | 06:25 PM
BOTTLEDZ28's Avatar
Transmission: A4
Kandid thanks for pics they look awsome. Do you have any pics of the install as it was being done. I am looking for pics of the mounting points of the main hoop. Also, what angle did you put the hoop at? I have mine in line with the B piller but it seems like yours is farther back then mine.
Old Mar 15, 2004 | 02:07 AM
Kandied91z's Avatar
no unfortunately i don't have any pics of actual progress. the cage follows the lines of the car. i made three demands and let the shop do it as i have no idea how to do that stuff.
1. had to be 6pt.
2. had to be as out of the way as possible(basically try to make it not seen).
3. had to be chromoly.
number 2 was a huge deal. i absolutely hate cages in cars. but i needed it as my body was flexing causing the issues. i don't use the rear seat so that wasn't a loss but i've been around enough cars to know that typical cages are a pita to get in and out of and the rest so that's why it was done the way it's done. it's still very functional and serves its structural purpose however unless i pointed it out most never even notice it.
if you need specific pictures taken of points i might be able to do that but that's the best i can do. sorry.
Old May 10, 2004 | 08:50 AM
Engine: 311
Transmission: T-10
does anyone have pics of a 10-point or 12-point setup? just courious. thanks, Patrick
Old May 10, 2004 | 07:09 PM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
the sw race cars cage is prebent to clear the door handles, I have it in my toilet and they work great!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
shanelique22
Oct 3, 2015 07:23 PM
FormulaEngland
Sep 30, 2015 01:50 PM
