foglights should i replace?
Old Apr 13, 2004 | 11:14 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
well one of my foglights on my 90 firebird is very dim, i thought it was the bulb but when i opened her up i noticed that the metalic lining that reflects light was peeling!. should i replace the whole foglight, *(which i dont want to do) , i hate myself for saying this but you think i can spray paint some metalic in there?, will it shine the same, i hate spray painting anything i think its so stupid but hey if it beats me replacing the whole unit i'll do it, anyone have any suggestions, ideas.. thanks
Old Apr 13, 2004 | 11:42 PM
joshp14's Avatar
They arent very cheap from GM. See if you can get a used one from hawks...so that's what I would do.
Old Apr 14, 2004 | 01:01 PM
Car: 1990 firebird
Engine: 3.1 v6
yeh let me see if i they have any third gen in the local junkyards. i might head out there ina lil while
Old Apr 14, 2004 | 01:12 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
The bulb (the lens and the backing plated thing that are peeling) are available at AutoZone. I got a pair for 14.99 and a couple "pure white" bulbs for $6. They were a universal set, and all I did was take the actual light part out and threw the rest away. Then I put them into the factory GTA brackets, and viola driving lights bright enough to drive at night without my headlights. There was a little re wiring, but it's 2 wires per side. I cut the GM plug, soldered in a quick connector to match the aftermarket bulbs, and I was done. The best thing is, they still have the GM weather pack connector to plug them to my car, but behind the light they accept cheap aftermarket bulbs and lenses. You couldn't tell that I'd done anything if I did'nt tell you. Look into it.
Old Apr 14, 2004 | 05:18 PM
Car: 1990 firebird
Engine: 3.1 v6
thats cool, i actually went to autozone today and i had seen a pair of aftermarket lights that are called blazer, they look just like our foglights, i seen someone speak about blazer in another topic, i might just get that 20 bucks for the pair , i went to 2 junkyards and didnt find anything, only thing i found that was cool was a camaro posi, 400 bucks, seemed in good condition, at least to me , while i was walking in i got happy seeing a formula go in , i thought they just were about to junk it, but it seemed to be the owners car , stick shift , banged up but looked nice inside
Old Apr 15, 2004 | 12:45 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Yep, Blazer, those are them. It comes with wires and a switch and the housing. I just threw all that crap away and used the "bulbs". They look friggin awesome. I had one broken retaining clip (the piece that the screw goes thru to hold the bulb in the housing) and with a little trimming I was able to use one of the Blazer ones to replace it.
Old Apr 15, 2004 | 07:49 PM
Car: 1990 firebird
Engine: 3.1 v6
are they hard to install? i dont want to take off my bumper!
Old Apr 19, 2004 | 01:07 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Not too tough at all. All you have to do is jack up the car (you may not have to, but mine is lowered about 2-2.5 inches in the front) and undo the bottom of the front splash panels. Then you just reach up there and take the bolts out and viola, they come out. It takes a little while loinger the first time, but when you've changed a couple lenses it is easy.
Old Apr 19, 2004 | 05:19 PM
Car: 1990 firebird
Engine: 3.1 v6
cool, first time i tried taking mines out i undid the bottom like you said, i felt it , just didnt have a jack at the time .. thanks alot
Old Apr 24, 2004 | 10:32 PM
LostInPlace's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
Hey everyone, I'm new here so I'd appreciate all help and opinions. The stock fog lamps on my 91 firebird don't work and I'm sure that its the wiring by the actual lights. I decided to do what other people here have done and get those Blazer lights. But when I tried to put them in, I saw the difference in the housing and wiring. I don't know much about ectronics, but if anyone can give a detailed explanation on getting these Blazers to fit and wire in, I'd be very grateful. Thanks guys.
-Rob
Old Apr 25, 2004 | 12:00 AM
Car: 1990 firebird
Engine: 3.1 v6
yeh gta spd, i think you did this swap, im llooking forward to doing this to, real soon too, now i really need to replace them being that my lense came off from my busted foglight and the **** is hanging all over the place , im about to rip it all out
Old Apr 25, 2004 | 05:07 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
I still don't know how to get my foglights off. I don't know what this "splash guard" is...
Old Apr 25, 2004 | 09:14 PM
Car: 1990 firebird
Engine: 3.1 v6
its under the car, if you jack it u can get to it easily, but even if you dont just go in front of your car and look under it, it has about 3 screws holding it , its right under the bumper, and in front of the wheel
Old May 2, 2004 | 06:44 PM
Car: 1990 firebird
Engine: 3.1 v6
so i bought the blazer foglights, im pretty impressed , i like them alot, took a while to see how i would do it without messing anything up, so i gutted out the blazer and put the guts inside the stock unit, there was no way id be able to put the whole blazer unit without fabricating some mounts, let me know what you guys think .. i like them .... nice and bright
Old May 2, 2004 | 06:47 PM
Car: 1990 firebird
Engine: 3.1 v6
ha this pic is kind of funny, my hatch is open but it sort of looks like there is a van behind my car with a wing on the front
old fogs, gutted out blazer mount
Old May 2, 2004 | 08:41 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
The Blazer set is the way to go. Had mine for about a year now. There is a set done by Hyper-White also. I use 100 watt bulbs and never use my headlights. Passed many cops, coming and going, and haven't been stopped yet.
Jim.
Old May 2, 2004 | 10:12 PM
Car: 1990 firebird
Engine: 3.1 v6
yeh i noticed how bright they are i dont even need to put my headlights on, even when i do the foglights are way brighter... i drove it tonight for about an hour , id rather have the foglights on , , the flipping headlights arent my favorite , thats about the only thing i hate about birds
Old May 3, 2004 | 06:24 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
You can watch people "jump" when you come up behind them in the #1 lane, about a car length or two, and then I pop my headlights on. I use the Cool Blues lamps. Bright as hell.
Jim.
Old May 3, 2004 | 07:19 PM
Car: 1990 firebird
Engine: 3.1 v6
so do you think blazer purposly made these lights for us firebird owners or do they just happen to make foglights that are the same exact size as the stock ones, cause its a coincidence * sorry cant spell*
Old May 3, 2004 | 07:48 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
Well, if Blazer did it on purpose, it'd be nice if they made a housing that actually fit
Old May 4, 2004 | 02:33 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
I feel pretty stupid now. I bought a set of blazers after reading how lots of third-gen owners are satisfied, but now i think i shouldn't have. I have a 91 bird and I guess its different than earlier years cuz my stock fogs have sort of an angle to them, they're not rectangular. The Blazers are rectangular (like other bird years?) and would fall right out of my stock housing. I've gotta do some thinking now, cuz I'd like to still use them...
Old May 4, 2004 | 02:52 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
See what I mean?
Blazer on the left, stock on the right
Old May 4, 2004 | 05:04 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Blazer might have been the original subcontractor for the lights.
Anyhoo......get down to your local Harbor Freight Tool store today. They have the fog lights set on sale for $7.99!!
Just remove the backs and use the insides, lamps and front glass. It's a steal!! (I picked up two sets.)
Jim.
Old May 4, 2004 | 08:14 PM
Car: 1990 firebird
Engine: 3.1 v6
LOSTINPLACE- did you try putting the insides of the blazer in your stock mount, im not sure but to my eyes it seems like it will fit, i could be wrong, thats what i did
Old May 4, 2004 | 08:39 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
Yea, but since the blazers are rectangular , they are smaller on one side than the stock were. The side plastic pieces won't hold it in.
After playing around with it, I found that it'll stay if i put the guts in the stock mount, but use the old glass lens too. The lens will hold the guts in, whereas the blazer glass wouldn;t. Now I just need to find a way to reconnect my old wires where they rusted/corroded/broke apart. Thanks
Old May 4, 2004 | 09:16 PM
Car: 1990 firebird
Engine: 3.1 v6
hm i still kind of dont understand how u think it doesnt fit.. i dont think our foglights are different ...are they?, as far as wires go, i just took off the little clamp on the stock black wire and striped it a bit, with the striped part i tied it around the little screw that holds the bulb in your new blazer light. then the red wire just clamps on , no need for stripping of any sort
Old May 4, 2004 | 09:29 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
He's got a '91 so the shape is different.
LIP - If you put the guts inside, will they hold in place in all directions? If the reflector or bulb is able to move a little bit, it'll probably throw off the aim.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
