anybody replaced these?
Old Dec 16, 2004 | 02:27 PM
Dora's Avatar
Car: 1986 iroc
Transmission: auto
Hi
86 Roc
i am getting a replacement set of the mouldings that are at the very top of the inside doors. (what you MAY rest your arm on) they are both heat cracked. Can any one tell me how they come off? Are they just clipped on and do you use a screwdriver? What is the best way?
Thanks, Dora
Old Dec 16, 2004 | 02:30 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
u got a pic dora? im not sure if you mean armrests? www.yearone.com and www.classicindustries.com also www.ecklers.com have em'... good luck.....
Old Dec 16, 2004 | 03:09 PM
Dora's Avatar
Car: 1986 iroc
Transmission: auto
Hi not armrests, like this: http://cgi.ebay.com/ebaymotors/ws/eB...940209470&rd=1
Old Dec 16, 2004 | 03:13 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
oh, ok.... yeah, u can get those from those sites or catalogs. i have em all at home... so if need a part # or price i can get it after work......( 4:30 pm est)
Old Dec 16, 2004 | 03:14 PM
Dora's Avatar
Car: 1986 iroc
Transmission: auto
I have them, how do the old ones come off?
Old Dec 16, 2004 | 03:19 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Theres like inverted nuts on the back side that screw onto plastic studs. Be very careful taking them off as the plastic gets pretty brittle.
I used a needle nose pliers to unscrew the nuts off.
Old Dec 16, 2004 | 03:20 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
if i looked correctly: yearone.com: molded door top rails, $139.00/pr... DAMN! thats expensive!
Old Dec 16, 2004 | 03:22 PM
Dora's Avatar
Car: 1986 iroc
Transmission: auto
Did you at first pry it up with a screwdriver? How do you get at them?
Old Dec 16, 2004 | 04:20 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
You have to remove the door panels first. They are attached to the panels.
Or did you mean how do you remove the door panels?
Old Dec 16, 2004 | 04:27 PM
Dora's Avatar
Car: 1986 iroc
Transmission: auto
How do the door panels come off then?
Old Dec 16, 2004 | 04:34 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
I have mint black ones, I'll sell 'em to you: $60
Old Dec 16, 2004 | 06:46 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
First you'll need to remove the arm rest. Theres 3 torx screws that hold that on.
Theres a couple small torx screws around the door handle, be careful though some are fake and just molded plastic to make it look like screws. Then that trim panel comes off. The door lock indicator is snapped onto a rod, you'll need to muscle that off.
Then you'll need to slide like a putty knife around the outer edge of the door panel and pop up all the press in clips that are around the door. Theres probably 5 on each side and I think 5-6 on the bottom.
Once you have that all done the top of the door panel hangs on the inner door frame. You need to gently hit the top of the door trim down and inwards toward the glass to get the top to "pop" off.
The door panel will come right off then. On the backside of the door panel are the nuts that hold that trim piece on.
It sounds much more complicated then it is.
Old Dec 17, 2004 | 06:32 AM
Dora's Avatar
Car: 1986 iroc
Transmission: auto
Thank you Karps!
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
