Weight reduction Vs. Safety
Old Feb 9, 2005 | 10:27 PM
NEEDforSPEED's Avatar
i think a lot of useless weight could be saved by taking off the metal that holds the honey combs, or at lest making something like them out of aluminum? This is what im talking about...
anyother weight saving mods? beside a fiberglass hood?
body wise....
Attached Thumbnails Weight reduction Vs. Safety-c-documents-settings-owner
Old Feb 9, 2005 | 10:39 PM
jay92,85,79's Avatar
Car: 85z28,
U will be wish that was there if u get in a front end hit. And you would have to have something under there or the bumper will sag. Iwas thinking of a way u could use a newer car reinforcement bar thats alum. Olds alero caddys and a few other cars use them. Would have to cut them down and drill some holes. With all the other stuff u have done I"m sure u u will thing of something.
Old Feb 10, 2005 | 08:10 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
the older cars, like 83 or so?? some of them had aluminum crash bars, and the weight savings wasnt all that amazing... it never will be if you want equal strength
anyways, i dont want to imagine the carnage from a serious accident if there was nothing there at all
even a minor impact will having nothing to hit except directly into your frame rail... another bad mod, if you actually drive the vehicle
Old Feb 10, 2005 | 09:10 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
do something like this
https://www.thirdgen.org/techbb2/sho...hreadid=263419
Old Feb 10, 2005 | 06:51 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
You could "swiss cheese" the impact bar with a hole saw like the frames on the Super Duty Pontiac Catalinas in the early 60's.
Old Feb 10, 2005 | 09:09 PM
i like, i was also thinking of swiss cheesezing the f*ck otta it,
Old Feb 11, 2005 | 08:07 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
My only concern with what ive done as well as that is that if i lose the support for the bumper cover it will start to sag quickly. I have already severly swiss cheesed my bumper
Old Feb 11, 2005 | 02:35 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
It's been mentioned, but I think the best options for the bumper support are replacing with factory aluminum parts or going with a custom made piece (check out the fabrication board for examples).
I also think there are better places to reduce weight that won't compromise structural integrity. Start with rotational mass first.... aluminum driveshaft, lightweight rims and flywheel. Maybe lightweight seats... the stockers weigh a ton. Drop any options that you don't use like A/C. maybe go with a tubular k-member. I guess it does also depend on what your reason for reducing weight is and how much weight you want to drop. lots of topics are out there about weight reduction.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Buickstaged
Interior Parts Wanted
Oct 4, 2015 11:49 AM
gord327
Oct 3, 2015 01:25 PM
Damon
Sep 26, 2015 04:29 PM
PeteK825
Sep 22, 2015 10:47 AM
