Need help with a dash
Old Feb 16, 2005 | 12:37 AM
ecmagee1984's Avatar
Car: 1987 z28 camaro
I found a good dash at the junk yard, I want to know is it hard to get out of the firebird and what tools would I need to get it out?
Old Feb 16, 2005 | 12:39 AM
82knightrider's Avatar
Transmission: TH200C....700R4
Are you talking about the dash pad?
Old Feb 16, 2005 | 12:58 AM
Yea im talking about the dash pad part.
Old Feb 16, 2005 | 01:12 AM
Ok,all you need is a nut driver I forget ewhat size though and you might also need a screwdiver.Its as simple as changing an air filter.Just make sure you have all the screws out before you try pulling it out or else you could damage it.
And welcome to tgo,I just noticed it says you have a camaro so if youre trying for a firbird dash it wont fit
Old Feb 16, 2005 | 01:26 AM
Old Feb 16, 2005 | 02:46 AM
Is there anyway to get the firebird dashpad to fit in a camaro?
Old Feb 17, 2005 | 10:35 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
We transplanted a 91 GTA dash with electronic cluster into a 87 Camaro. It's not an exact bolt in job but it will go in with a little fabrication. We also re-used all of the heater ducts from the GTA, they will mate up with the Camaro heater box, then installed the GTA center console.
Old Feb 17, 2005 | 10:42 AM
Wadebryant's Avatar
I've found that Camaro and Trans Am dash pads will interchange ok. They do differ if only in appearance, near the upper heater vents, speaker covers, and side vents.
Old Feb 17, 2005 | 10:51 AM
hmmurdock_00's Avatar
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
The firebird dashpad won't fit a camaro's dash, at least it didn't in my 92. The firebird dash was almost a 1/4 inch smaller on the sides and almost 1/2 to narrow.
Old Feb 17, 2005 | 11:19 AM
Wadebryant's Avatar
Hit and miss I guess... when mixing parts / years.
Old Feb 18, 2005 | 12:57 AM
Thanks for all the help. If i get the dash pad, I will let yall know how it came out.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
