auto shift knob button delete
Old Mar 13, 2005 | 06:00 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
auto shift **** button delete
ok well i searched and searched and no luck pretty much what i am looking to do is the get an aftermarket shift **** altho i want to get rid of the damn button on the auto shifter is there a way this can be deleted out so i can thread the shifter stick and put an aftermarket **** on?
Old Mar 13, 2005 | 06:53 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
i think it would take alot of work since if you keep the button pushed in all the time the key will not turn completly off so if your key dont come out till there then you dont get key out and it wont shift into gears with it up all the time id think you would have to go into the colum somhow
edit but just thinking those b&m shifters have it so you dont have to push a button anymore so i dunno
Old Mar 13, 2005 | 07:52 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
a guy i know put a manual shift **** on his auto shifter- you pushed the ball down and it would shift into gears- it was acually pretty neat.
Old Mar 13, 2005 | 08:45 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Just take your console apart and see how the shift lever works. The button pushes down a detent that allows it to go into certain gears, and protects it from going into others. Disable that and you can do whatever you want. Like now being able to accidently throw your car into reverse/park doing 65 mph. But hey atleast your shift **** will look cool. I'm sure the tow truck guy will be impressed.
Old Mar 13, 2005 | 10:14 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Buy an aftermarket shifter and you won't have to worry about the button or going into reverse at 65 somehow.
Old Mar 13, 2005 | 10:26 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Do you guys know anybody that sales aftermarket shift ***** for an auto? I would also like something different than the ball alrdy on there.
Old Mar 13, 2005 | 10:46 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
go here and admire as well as notice that it has a b&m shifter with momo shift **** im going to go with the same setup on my car very soon
go here
Old Mar 14, 2005 | 01:07 AM
Car: 86 z28
well for one im not exactly sure how you could accidently throw it into reverse going 65 cause i sure aint shifting or even touching the shifter when driving unless i have to but i do see your point i guess it could happen also i might just buy a b&m or hurst and get a pistol grip
Old Mar 14, 2005 | 07:22 PM
sellmanb's Avatar
Car: '86 Berlinetta
I've actually put the car in reverse while driving 65. I could have sworn that I left it in Drive and not Overdrive (since most the time it's in drive because it searches for the right gear in overdrive in the city)... so I pushed it up twice to get into Neutral so I could coast for a while (it was going down hill for about a mile and a half, figured coasting was a good idea).
So I stuck my finger down, shifted up two and *CLUNK* the car turned itself off. I realized what I had done just before I put it into reverse, but it was too late by then.
That was SCARY. I am now trying to figure out how to relocate my shifter w/o getting rid of any of the functionality, or safety taht there is in the original design which possibly saved my life that day.
(I'm trying to relocate it so I can use the auto console for 4th gens ).
Old Mar 14, 2005 | 08:00 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
threw a blazer into reverse at 72 on cruise control. scared the crap out of me!!!! I bumped the shift lever up while I was changeing the radio. the truck started to slide sideways but I caught it and then the ECM killed the motor. was able to get into N and roll off the road, but I was lucky. don't make it easier to do that. you will regret it very much. get an aftermarket shifter for your safety and everyone else around you.
1992rs/ss's Avatar
Old Mar 14, 2005 | 08:52 PM
Stevo's Avatar
Car: Pair of 92 Z28s
ive put a car in reverse while going about 30-35 (accidental of course) and all that happened was a small grind and the motor just shut off...no real damage
people grind gears all the time in manuals so i wouldnt be worried about it doing it once
im sure its not GOOD or anything but nothing like u need a new tranny if u do it accidentally.
Old Mar 14, 2005 | 11:22 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
hehe, i gots a funny story. Guy I worked with was having trouble w/ the tranny in a blazer he had leased. Well a tranny shop worked on it and they thought they had the problem fixed (i think it wouldnt go into OD or something). So they're out testing it out, first time they get going fast enough to go into OD, the thing goes into OD, and then shifts again, right into reverse. I dont know if the ECM shut the engine off or what happened, but i know it didnt happen fast enough for some reason b/c the tranny was totally destroyed, he wound up getting a new tranny outta the whole ordeal.
but yea, go aftermarket, i think they look better.
-chillen
Old Mar 15, 2005 | 03:04 PM
coolcamaroZ28's Avatar
Car: 95Z / 91Z / 10SS
Engine: LT1 / LB9 / LS3
Transmission: T56 / 700R4 / TR6060
The hurst Dual/gate is the shifter of choice when looking to eliminate the button (imo). But here's another idea, they say they are for 4th gens, but someone here must know if the regular shift ***** are compatible, if so, we must assume that these shifter ***** will fit as well... --John
These shifter ***** can be found at www.mbaproducts.com
My hurst dual/gate pics are at my site: www.coolcamaro.cz28.com
Attached Thumbnails auto shift knob button delete-c-documents-settings-jriccian
Old Mar 3, 2012 | 03:26 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: auto shift **** button delete
I'm going to bump and old thread here, but everything I've read, is that this is for 4th gen's only...unless the auto shifter for the 3rd and 4th gen's is the same. Then there is no reason why it wouldn't work. I'm looking to do this in mine this year sometime.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
