turn signal mounting?
Old Mar 20, 2005 | 09:12 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
i recently finished redoing my front end after a wreck. i need to know how the turn signals in the front mount on. pics would help. all i see is 2 slits on each side. thanks.
Old Mar 20, 2005 | 09:44 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Its as easy as changing an air filter,hope that helps
Old Mar 20, 2005 | 10:59 PM
eagle_eyes's Avatar
Engine: '93 LT1
i don't have any of the hardware, and i never took the old ones off...they were shattered. does it use bolts or what?
Old Mar 20, 2005 | 11:03 PM
stiers's Avatar
They use special clips that go through the holes in the fender and then go through the turn signals and clip on.
Old Mar 20, 2005 | 11:06 PM
eagle_eyes's Avatar
Engine: '93 LT1
do you know what they look like and where i can get some??
Old Mar 21, 2005 | 09:30 AM
stiers's Avatar
I would have to take a picture, but I don't have a camera right now. Hopefully someone else has a picture of what they look like.
Old Mar 21, 2005 | 09:35 AM
eagle_eyes's Avatar
Engine: '93 LT1
pics would definitely help if anyone has some
Old Mar 21, 2005 | 11:38 AM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
id say go to your local gm dealer and buy the parts.
Old Mar 21, 2005 | 01:25 PM
Ill see what I can do for you .If I see some at the yard Ill get em for you
Old Mar 22, 2005 | 12:46 PM
eagle_eyes's Avatar
Engine: '93 LT1
any help at all would be great
Old Mar 24, 2005 | 12:57 PM
eagle_eyes's Avatar
Engine: '93 LT1
anyone know where i can get these...autozone, o'reileys, etc...i hate the dealerships around here.
Old Mar 24, 2005 | 01:00 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I can't imagine these are quite common from retailers. I'd say hit up a junkyard.
Old Mar 24, 2005 | 10:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: turn signal mounting?
Old Mar 25, 2005 | 02:09 AM
eagle_eyes's Avatar
Engine: '93 LT1
thanks for the illustration. that helps enough to where i know what to look for.
Old Jul 11, 2012 | 12:31 AM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
Anyone have a good alternative to these plastic nut type things which mount the turn signals?
Mine just basically crumbled...
Old Oct 29, 2014 | 05:22 PM
RQ Jay's Avatar
Car: 1985 TransAm
Engine: 4bbl 305
Transmission: Automatic
Sorry to bring up an old dead thread... but does anyone know the name or GM part number for the Oval shaped clip ? Its number 3 on the right image.
Old Oct 29, 2014 | 08:27 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
It's actually called a nut,GM P/N 3999700
Checkout this site,http://www.clipsandfasteners.com/Gro..._s/104.htmthey have them,their under a different P/N,I may have given you a old P/N.
These look like what your looking for,I don't recall the screw size
http://www.clipsandfasteners.com/Nyl...t_p/a12713.htm
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
