Too good to be true????
Old Jan 16, 2006 | 11:25 PM
subliminal's Avatar
I was looking in my JC whitney catalog yesterday and saw an ad for a device that is supposed to prevent rust. It is supposed to work by running some kinda current through the cars entire body, Says it uses a 12v battery to feed a vehicle ateady flow of free electrons to interrupt the corrosion process. Im not too familiar with the way metal works so maybe someone a little more experienced came chime in? Would this really work or is it just a gimmick?
Old Jan 16, 2006 | 11:58 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Hmmm. Sounds a bit shady to me. electrolytic corrosion certianly DOES occur, especially in cooling systems that arent propoerly grounded/ set up. The flow of current literally eats away the metal. This is also a problem in the fuel systems of cars that run on alcohol... I dont know about electrolytic corrosion throughout the entire body... What parts would be the cathodes/anodes, on a body that is made up of the same material, welded together and (hopefully) properly grounded?
If it sounds too good to be true, it probably is... I would like to see a study of this product in action though...
Old Jan 17, 2006 | 07:28 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I've seen then installed on a bunch of cars. I couldn't tell you form personal experience, but the cars that I saw didnt have much rust.
Old Jan 18, 2006 | 02:00 AM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Your car already has a steady 12V current flow. It's called the charging circuit, and it uses the body sheet metal.
Cleaning up all your body grounds will almost certainly fix ground-related problems better than installing a battery in a questionable manner.
Old Jan 18, 2006 | 07:09 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Those things are a crock. They don't work. Like already mentioned, there are already plenty of electrons running through your car's body.
My father's 94 F150 had one of those widgets, but it didn't stop all of the air conditioning and power steering lines from rotting off the truck within 70k miles. His oil pan wasn't far behind either.
Old Jan 18, 2006 | 08:51 AM
Epro's Avatar
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
Correct me if I'm wrong, but I believe it is supposed to be used in conjunction with undercoating.
http://www.ruststopnorthamerica.com/
Old Jan 18, 2006 | 09:24 AM
Jim85IROC's Avatar
it's marketing bull****. Undercoating will have absolutely no effect on the electrical properties of the steel. If this gimmick worked, it would do it with or without undercoating.
Old Jan 18, 2006 | 10:55 AM
subliminal's Avatar
Thanks for the info, I wont be buying one
Old Jan 18, 2006 | 11:21 AM
85_ZED28's Avatar
Car: '85 Z28
I think there is more to them than just passing current through the car. I remember something about capacitive pads or someting??? Heres a link
http://www.counteractrust.com/capacitive%20coupling.htm
Don't know if it works though
Old Jan 18, 2006 | 01:44 PM
subliminal's Avatar
I wish i could get a hold of one and test it out on a bare piece of sheet metal.
Old Jan 18, 2006 | 03:01 PM
Jim85IROC's Avatar
What a complete crock. Capacitive coupling, a term they misuse, is nothing more than inserting an inline capacitor (and usually a shunt resistor) to filter DC out of an AC signal. It has no effect on polarization of electrons or any of the other nonsense they spew on that site.
That site's explanation is pure bullsh*t with a little bit of incorrect technical jargon sprinkled in to intentionally fool those who don't know better.
Old Jan 18, 2006 | 03:54 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
But, what do you really think about them Jim ?
Old Jan 18, 2006 | 05:04 PM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
por15, ospho, there r a number of products that r suppose to treat or prevent rust
Old Jan 18, 2006 | 09:08 PM
hmmurdock_00's Avatar
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
I once had to do a presentation in school on the wonderful world of corrosion, and like Jim this sounds like BS.
The usual way to prevent rust is to take a wire attached to one metal lets say steel, and run it to a more corrosive prone metal like iron, or something else. This will cause electrons to pass to the anode (sacrafical metal) being the iron or more corrosive material. Therefore prevent or slowing the rust of the other metal called the cathode.
They use this on large tanks buried under the ground, namely gas stations.
They are other ways, but if passing electricity through a metal, then are cars should never rust, they have approx 12 volts when turned off, and i think 13.5 when charging(correct me if i am wrong here).
I believe stainless steel will start oxidsing at large amounts of voltage. Seeing how we don't drive DeLoreans this isn't a problem. If we did, then we wouldn't be having this therad at all.:P
Corrosion or oxidation is the lost of electrons of a metal. This is why copper or lead will oxide quicker when exposed to a current than, without, but still happens.
Old Jan 18, 2006 | 09:34 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I'm a maintanance electrician at a MCAS.One of my responsibilties is the cathodic protection system for the underground fuel tanks,fuel lines and gas lines.Like Toehead,Jims85 and hmmurdock point out the only way to slow down corrosion,there's not way to completly eliminate it,is thru the use of cathodic protection which does use DC current to excite the anode beds(think of these as being sacrificial part of the process)but that's the extent that electricity plays in the process.The fuel lines and tanks also have anti-corrosive coatings applied.
okfoz
Mar 9, 2017 02:35 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
