Redoing the front end.
Car: 1991 Z28
Engine: SBC
I'm just wondering how i can prep the front end for paint. The paint is rough in some places. I don't know what to sand it with to get it all smooth and ready for priming. Anybody?
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
personally id use some light sand paper and get it by hand. some people say you can use a DA on it, but i think id just do it by hand. it shouldnt take you too long to sand it down.
Car: 1991 Z28
Engine: SBC
alright thank sounds good, i figured i was gunna need something like 180. Alright thanks for the help, appreciate it
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
180 on a DA will take it down rather quickly, then you can redo it with 220 on the DA to get it real smooth. I don't usually going over it later with a block and 320 because the urethane is so deformed that blocking it is a waste of time.
For the amount of work involved with getting rid of those spiderweb cracks in the lower valance, I'd pick one up on Ebay that's in better shape and not bother wasting my time with that one.
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
You can buy a chemical stripper that will not harm the rubber, it makes a real nasty mess but won't dig in to the rubber like sandpaper will.
Car: 1991 Z28
Engine: SBC
i acutally used aircraft remover on the front end...did a great job...nice and smooth for the most part and makes the car look much much better. Could use alittle sanding but im extremely happy with the results..
Car: 1991 Z28
Engine: SBC
oo yea deff....the front ground effects i guess i will replace. Im gunna sand the front end a bit so its perfectly smooth (hopefully)
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
I just got done doing this to my car. I got in a fight with a tire on the highway last fall..
I would completely strip your bumper down to the rubber.. The cracks are all the way down to that and you will not get them out otherwise.
I started with 80, then i went to 180 on the da. Don't hit the lips or edges with the da because it will cause flat spots. After hitting everything with the DA, I went over it with a soft block with 180. Then you can use pre-clean to find any cracks that might still be in your bumper. Trust me, a few will show up!
Also, is some are very minor, they will come out when you wet block the primer.
Yes, i know it is a pain in the ****, but if you want it to look good, you'll take the extra time.
Car: 1991 Z28
Engine: SBC
yea i just tried the same trick on the rear bumper..what a mess...looks like **** lol.
Looks like im going to have to sand. Ill follow your example with the 80>180 deal
Car: 1991 Z28
Engine: SBC
ah well i got a pad for a normal drill and some adhesive sand paper and went at it...used a pretty slow spinning drill and 8 grit..much better
but now my bumper is pink lol...i guess it was red and painted over?..not sure but it looks kinda stupid lol o well...at least its stripped
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
