Cheap Cupholder
Old Apr 27, 2006 | 11:03 PM
weigesco's Avatar
Car: 89 RS Convertible
Engine: 350 Carbed, No Computer
Cheap Cupholder
I have been struggling without a cupholder for to long now. Not any more. After trying unsuccessfully to find an actual sunk in cup holder, I stumbled accross this at work. It fit perfectly and I think it looks pretty good. What is it you ask. It's a $2 pencil holder from Staples. Big enough for 20 oz. bottles and deep enough that it's not in the way.
Old Apr 28, 2006 | 01:43 AM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
works and looks good for $2
Old Apr 28, 2006 | 07:25 AM
Slave One's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
Dude, thats actually pretty cool...
You should also hook up an LED through the bottom so that it would illuminate a bottle of mountain dew or something...
now that would be cool!
Old Apr 28, 2006 | 08:50 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
Maybe I'll try that. Did you drill that out or cut it out?
Old Apr 28, 2006 | 10:54 AM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
That rocks. i think that's my next mod.
Old Apr 28, 2006 | 11:37 AM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
I have the exact same pencil holder sitting on my desk right now! It might not be there for long. I don't want to risk messing my console up so how did you do yours?
Old Apr 28, 2006 | 04:54 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
COPYCAT! nah just playing. i did this exact thing about a year ago.i dont have power hatch or windows so it worked out great. i paid more than $2 though. i didnt like that it could be pulled out, so i pulled up the shift panel thing and zip-tied a coozy around it (had to cut the coozy to fit). this made it a little more secure and keeps it from wiggling. the size is cool, because my liter-sized aquafina bottles fit in it. good work man!!!
Old Apr 28, 2006 | 05:03 PM
Car: 89 camaro rs
Engine: 305 tbi
forgot to give install tips. when i was looking for something that would work i was looking for a lip at the top. this has probably 1/4 inch lip all the way around. mine was a little tapered at the bottom which helped after i cut the hole. i just measured, found center of console. i used a drill and a jigsaw. the metal mesch actually helped me round it out after the hole was cut. once i got it were it would almost fit i just twisted until i dropped, makes for a tight fit. good luck. and highly recommended.
Old Apr 28, 2006 | 05:56 PM
rmchugh's Avatar
Car: 89 Iroc
Transmission: automatic
Axle/Gears: 373
finished look
nice! it has a nice finished look!
Old Apr 28, 2006 | 09:07 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
The only thing I can see a problem with the mesh thing is that the dew from what ever is in the holder may get some of the elctronics wet underneth it. Ofcourse this is just a what if. But if you add a coozy to it like dan_o_89_rs did, it would fix that problem and keep the drink cold longer also. I think I might try this out. Ecspicaly if I can fit a 20oz in there. Adam :-)
Old Apr 29, 2006 | 12:35 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
if you guys are looking to do this use a hole saw to cut the hole.
Old Apr 29, 2006 | 09:39 AM
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
sweet! I was thinking about this very thing...only, in my case, I'd have to relocate the power window and power mirror controls up a little to make room.
Was it an easy modification? Any pitfalls I should watch out for?
Old Apr 29, 2006 | 10:30 AM
Vaneat-91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
I'm thinking that as many console pieces as are available on e-bay, you could buy one cheap to modify, and keep your good one in case when/if you have to sell so you could return it to stock. Cool mod.
Old Apr 29, 2006 | 01:06 PM
91 v6's Avatar
Car: 2002 ranger(showtruck) 90 firebird
Engine: 3.1l
that is great, im missing the cup holder on the door of my firebird and have to put my coffee from dunkin donuts on the passenger side door,(and thats a far reach). this is something one of my fellow mini truckers would come up with
Old Apr 30, 2006 | 02:26 PM
Car: 89 camaro rs
Engine: 305 tbi
thats what i was going to use. i dont remember the diameter needed, but i remember having problems locating a holesaw that big. plus i didnt wanna spend more money than needed.
Old Apr 30, 2006 | 09:27 PM
weigesco's Avatar
I used the bottom of the holder and drew a pencil line around it on the console.Then got out my rotozip to cut it. I also wrapped it with a piece of felt to absorb any moisure and glued it down using some rubber and trim adhesive.
Old Apr 30, 2006 | 11:24 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Something I have at home that would work is the cup that's used in a dice game, whats that game called?
anyways, it's lether, has no holes, and is pretty solid, big enough to use as a cupholder.
I got mine for 1$
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
Damon
Sep 26, 2015 04:29 PM
