91 RS Steering Column Question
Old May 4, 2006 | 02:55 PM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
My 16 year old son just bought a 91 RS Camaro for his 1st car . It has tilt wheel. The steering column seems to have some play in it as I noticed it by holding on and pushing down on the wheel getting in and out of the car. It goes down and left. I have since looked at several of these same year cars in junkyards and car lots, they all seem to do the same thing. This one seems a little worse than most of the others I have checked. Does anyone know anything about this? Take it in or do it yourself? I don't wanna see the airbag! We can't drive it yet untill He gets license plate, drivers license and insurance. He spent his funds on the car and some other things to fix it up. I'll be a good Dad and wrench on it with but he pays for parts. Any help will be appreciated.
Old May 4, 2006 | 03:20 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
https://www.thirdgen.org/steeringcolumn
Old May 4, 2006 | 03:22 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
I am currently doing this fix right now. My best advice is to search this site far and wide. There are tons of articles on this. I have prolly read about 50 articles on this repair. there is a article in the tech section as well at the home page
Unfortunately I stripped one of the bolts that you must tighten in the column. there are 4 inverse torx screws that tend to loosen up over time. Now I must fix that before putting it back together.
My best advice: be very patient and take your time, especially if it's your first time like it was mine.
Good luck!
PS: welcome to the boards.
Old May 4, 2006 | 03:29 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If you've got an Autozone nearby they will loan you the wheel puller and lock plate depressor.
Old May 5, 2006 | 01:32 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
This problem with tilting down and left seems to be common in the early 90s years.. I sent my column out and had it rebuilt.. My 4 torx bolts (which werent even torx bolts on my year) was not the problem causing the wheel to tilt down/left.. I think the guy said it was something with the housings worn out.. I think where the pivot pins go in.. Cost a small fortune to have rebuilt but it doesnt tilt anymore..
Old May 5, 2006 | 02:40 PM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
Thanks for all the relpies! Haven't decided which way to go yet. I'll keep ya all posted. thanks again !
Old May 7, 2006 | 10:36 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Axle/Gears: 3.08
Uh oh......i hope what slayer6669 was talking about isnt what is wrong with mine. I have spent way too much time on it to have it be another problem!
Slayer6669: Out of curiosity, how much did it cost to have it rebuilt??? And did you just take it to a dealership?
Old May 8, 2006 | 12:29 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
one thing to check before you yank the colum. undernieth the dash ar two 15MM nuts that holt the colum tight to the dash, make sure they are tight, also check then two 10MM nuts @ the firewall. it will move if they are loose.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
