3rd Gen -> 4th Gen HVAC Controls
Old Jun 18, 2006 | 06:24 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well i looked on this site NUMEROUS times and couldnt find the right info, which compared to my vehicle. I unplugged the 3rd gen Heater controls from my vehicle, i have 1 connector and 2-3 metal wires i unhooked. 2 wires controlled the vent/heater/defrost, and 1 wire controlled cold/hot controls which on the 4th gen is the cable that came with my 4th gen heater controls. i havent seen this on any posts here, people are talkin about 6 colored wires i should connect, i dont have those. the connector i have to the right in the picture, i see this on the 4th gen controls i was told just to plug it right in, this controls the off/speed i see. but on top of that there are 6 thick colored wires. what do i do with these? any help would be appreciative.
Old Jun 18, 2006 | 07:16 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Are you talking about the VACUUM LINES? I think there are 6 of them.... purple. green, yellow, orange, etc ...?
Old Jun 18, 2006 | 07:20 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok so i took a pic of the connector and 3 wires in my vehicle. like i said 2 of them controlled what vents to go to, and the 1 underneath the controls controlled cold/hot air.
here is the 4th gen heater controls. the top connector is for my defrost, the second connector is the one i replace with the 3rd gen connector above. the middle cable is for the hot cold, assuming i have to replace the cable that was on the old one.
NOW what i dont get is the bottom one, this is with all the wires, i dont have this on my 3rd gen, i had 2 cable controlling the vents, now this has 6 wires, whad you guys do??????????
Old Jun 18, 2006 | 07:34 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Does your car have AC? Looks like you have the non-ac controls with just vent/defrost controls.
Kevin D.
Old Jun 18, 2006 | 07:38 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i didnt have A/C on my 86 trans am, but these 4th gen controls have air conditioning. any way to make this work?
i dont mean A/C to work, just so i can change vents like floor, defrost, etc
Old Jun 19, 2006 | 02:47 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ttt
Old Jun 19, 2006 | 05:18 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
how do you get access to the cable for hot/cold to change with 4th gen cable?
Old Jun 19, 2006 | 06:39 PM
Faded's Avatar
Car: '91 Firebird
I'm thinking the only way for you to get your setup working properly is to goto the junkyard and get the airbox that attaches to the firewall with all the vaccum servos. I've never seen a thirdgen with cable controlled vents.
Old Jun 19, 2006 | 07:00 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
jeese well i didnt have air conditioning, and it was carbed, someone must know what to do if you dont have a/c.
Old Jun 20, 2006 | 10:20 AM
Firebat's Avatar
It sucks, but this is the answer if you want the 4th gen HVAC to work.
Old Jun 20, 2006 | 11:25 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
the only thing this controls is where the heat comes out of right? i can get everything else to work but that? and it can come out of all vents?
Old Jun 20, 2006 | 01:08 PM
Faded's Avatar
Car: '91 Firebird
You should still be able to get the hot/cold and speed select switches to work. You could jam the doors open to blow through all vents all the time.
Old Jun 20, 2006 | 01:15 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yes i can get the speed control to work, and the hot/cold, if you dont mind me asking, where do i get access to that to change it with the 4th gen cable, i looked around but couldnt find nothing. only wire i found was to open and close a vent.
1992rs/ss
Jan 31, 2025 05:10 PM
eightsixseven
Dec 16, 2024 01:50 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
