subframe replacement?
Old Oct 24, 2006 | 04:42 PM
res1bxh3's Avatar
hey you guys i have one more quick question. is it possible to have your car put on a frame machine and pulled straight then replace a complete rear subframe. the reason im asking is the car im restoring has its rear right subframe bent and cracked open and im pretty sure im goin to have to replace the quater pannel as well.
thanks
Old Oct 25, 2006 | 09:25 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
With a unibody car you cant just replace the subframe because their isin't one it is all welded together if the damage is not too extensive a good shop can do a PULL on it and restore it to pre crash condition which will sometimes require parts replacement but it must be welded in on an alignment fixture ..
Old Oct 26, 2006 | 08:47 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
DUDE
4 link
Old Oct 26, 2006 | 12:22 PM
res1bxh3's Avatar
hmmmm jamon8 im liking your idea!!!
anybody know how streetable that is? it doesnt have to be the best handling car ever cuz i have a DD this is just a weekend/show/track car.
also suggested manufactuers? and prices??
thanks
Old Oct 27, 2006 | 08:20 AM
jamon8's Avatar
Engine: 350 tpi
very streetable
I would contact UMI and see what they can do
Old Oct 27, 2006 | 08:55 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
thanks
a 4link with a panhard bar is completely streetable... however you will occasionally want to replace the rod ends as they will eventually wear out some, and make "knocking" noises that can be very annoying.
if you plan on a decent amount of street driving, you can make them last longer by putting rubber sealing "booties" on the rod ends... but they all wear out eventually.
Old Oct 27, 2006 | 11:44 AM
res1bxh3's Avatar
hmmmmmmm very interesting
well ive been trying to do my homework and this is what i found so far
The Official S & W Race Cars Web Site
let me know what you think i will also contact BMR and see what they can possibly do for me
Thanks!
Old Oct 27, 2006 | 01:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Thanks!
dont waste your time calling BMR, UMI, Spohn or any other bolt on part company.
there is only two ways to do this.
1. do it yourself... THEN you look at comp engineering, S&W, ect... and buy parts to BUILD it yourself.
or most likely
2. take the car to a compatant chassis shop. this does cost a good chunk of money, but you can have a streetable race car afterward.....
also for this to make any sense, you'll also have a cage put in at the same time.. and id expect you woudl atleast PLAN on building a powerful drivetrain....
Old Oct 28, 2006 | 01:56 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Axle/Gears: 3.25 9"
We have done a few chassis kits on 3rd gen cars in the last couple of years with ladder bar or four link set ups mostly Chassis Engineering / Alston kits (these are mostly drag race / Pro Street cars) but I have seen other more street oriented kits out there .. they are quite work intensive and a challange to install at home but they can be done by someone with Good welding experiance and the space to set up and measure a frame ...
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Fronzizzle
Aug 9, 2015 01:15 PM
