formula buldge hood question
Old Jan 26, 2007 | 03:15 PM
85blkburd's Avatar
Car: 85 firebird
Engine: 305 ci. 4 bbl.
Axle/Gears: one wheel peel
I bought a formula buldge hood that is very nice , BUT the opening of the buldge is just open. What (and where??) can I get to keep water from getting under my hood?? I think I remember seeing something on ebay, it went from the opening to the throttle body but mine is carbed. Is there such a thing for carbed cars?? anybody ever had this problem or fabed anything to fill the hole?? all ideas appreciated
Old Jan 26, 2007 | 03:56 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
There were two setups I know of for the opening on the turbo formula hood.
on the early hoods for carb'd cars (82-84) they had a honeycomb mesh to cover the opening in the hood, and there was extra equipment inside to allow a inner flap to open at high speed so the carb could breathe cold air from the opening. I know I've seen a photo recently here, you may want to search for that.
on the later hoods (87-up) there was just a blank plate covering the opening and no extra equipment.
you should try bone yards fo these plates, I have seen both the mesh and the plate cover. they are cheap, I use the mesh on my hood, it allows the engine to breathe and acts like a heat vent. I don't use the other extra equipment though since my motor is an open element. I don't drive in the rain though, if you do you may consider using the block off plate.
If junkyards are not close to your area, I see the plates and the induction assembly in the classifieds from time to time.
Old Jan 26, 2007 | 05:47 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
On mine i have a mesh, but its breathable mesh, the water can still seep in. However, i guess you could call it a "drip rail", kinda like the gutters you have at the edge of your roof, its tilted, and directs water away from the engine. That peice is located just below the opening. Ill see if i can take a picture later.
Old Jan 26, 2007 | 06:32 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I just have a metal plate that holds 3 gauges in the hood
Old Jan 26, 2007 | 07:12 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I ran my '84 for 2 years without a cover on that screen, never had any problem with more than a few drops of water getting in. I don't know about formulas, but all V8 firebirds from 82-84 got that hood IIRC and they either came with a vacuum operated flap that channeled cold air to the aircleaner or they got a plastic cover.
Old Jan 26, 2007 | 09:43 PM
MNformula350's Avatar
here is a pic of the grille that was on 82-84 T/A's. I put the one off my old 83 on my Formula.
Old Jan 27, 2007 | 11:52 AM
84 trans am's Avatar
Car: 89 RS
Engine: 2.8
Transmission: t5
My 84 350 carb. has the vacum operated flapper and the channel to direct water away from the motor. Ive never had any problems with water getting inside.
Old Jan 27, 2007 | 12:15 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
yep, that is what goes in there. I have the whole set up for sale but I think someone was going to send MO this week. If I dont get it it will be for sale. Keep checking posts by me on this site.
jeff
Old Jan 28, 2007 | 11:45 AM
85blkburd's Avatar
Car: 85 firebird
now if I could just decide which way to go!!!! I think if the hole is there it should have some level of functionality !!!! But just blocking it off would be cheap, easy and give a cleaner under hood look. I'm gonna have to think about this a little bit. Thanks everybody
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Bert87
Aug 23, 2015 03:50 PM
redmaroz
Aug 16, 2015 11:40 PM
Randomtask2
Aug 13, 2015 01:57 AM
