I need new windshield trim.
Old Mar 18, 2009 | 10:47 AM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
Where is a good place to buy the exterior seal/trim piece that goes around the windshield?
Old Mar 18, 2009 | 10:55 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: I need new windshield trim.
i think i bought mine from modern day muscle, but Classic Industries also sells it. the prices are about the same
Old Mar 18, 2009 | 11:06 AM
Duratys's Avatar
Car: 91GTA 89TTA
Engine: 305 3.8 Turbo
Transmission: MK6 2004r
Axle/Gears: G80 3.42s 3.27s
Any place that installs windshields will have some. Make sure you get some urethane and primer to reinstall it.
Pull the old strip out. You may have to cut it out as you lift it straight up. Once its out you will have to cut and clean out the space that is left. The better its cleaned out the better your new molding will sit in. Prime the cleaned out area well. Fill the void a little better than 1/2 full of urethane and start at the bottom corner of the windshield by pressing the trim into the bed of urethane. Leave about an inch or so of extra trim. When you get to the top of the windshield at the corner you will probably need some masking tape to hold it down so it sits properly. Continue around untill you get it all in place. Make sure you leave about an inch or so extra at either end so you have something to grab when it needs to be removed. The trim will be easier to work with if its warm. Get it too warm and it will be tough to push into the bed of urethane. You may want to run some tape along the whole trim peice depending on how it looks.....if it dosent need it to stap put then your fine. Any areas that have excess urethane will need to be wiped down ASAP with a prep-sol or precleano type product before its allowed to dry.
Old Mar 18, 2009 | 01:28 PM
madhatter's Avatar
buy it from a windshield company, they buy it in bulk so it is cheap to get. cost me 5 bucks when i did mine
Old Mar 18, 2009 | 05:28 PM
Car: 86 IROC
Thanks guys. Sounds like itll just be easier to have the body man do it when he paints the car..... Much appreciated though!!!
Old Apr 9, 2009 | 12:44 AM
popballz's Avatar
Car: 89 firebird
So does this piece seal the windshield?
I would like to replace mine, but would rather not have to deal with it leaking in the future if i did it wrong.
Old Apr 9, 2009 | 12:55 AM
jagass's Avatar
I want to have info about this too...
Old Apr 9, 2009 | 10:10 AM
Duratys's Avatar
Car: 91GTA 89TTA
Nope not at all. Just follow what I posted and you will be fine. If the moulding comes out in one piece (some will and some wont depending on sun rot) this shouldnt take more than an hour or so to complete.
Old May 4, 2009 | 04:21 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
A little late, but after I took out my seal I noticed there was some kind of rubber gasket underneath where the weather seal sat. It looks pretty crusty and old so what should I do with it? Also, do I need to buy a specific seal for my car or are the seals universal?
Old May 5, 2009 | 01:46 AM
Duratys's Avatar
Car: 91GTA 89TTA
Thats the urethane bed your seeing there. They do get a bit crusty after being out in the elements for several years. If your windshield isnt leaking dont worry about it. You will need to remove the urethane in the gap where the trim piece was. Use a sharp olfa knife and cut along the side of the windshield and up against the top of the windshield frame and remove all the old urethane. Once you get it cleaned out follow the instructions I layed out earlier.
Bohemian
Aug 15, 2017 05:11 PM
Veaceonee
Sep 29, 2016 08:15 PM
codeysabatini
Nov 10, 2015 04:07 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
