Front Turn Signals
Old Sep 20, 2010 | 11:56 PM
Bajawoojie's Avatar
Front Turn Signals
Anybody ever have a problem with their front turn signals filling with water and leaving the inside of the lens dirty and dripping with water?
I just pulled one of mine out, cut off the old lens (It was glued on, I think?) And cut a new one out of a sheet of 1/8" polycarbonate. I'm letting the glue dry right now, and my plan is to clean up the edges once its dry, then spray a few coats of tint on it, and put a piece of rubber corner trim around the edge of the lens to cover up my rough edges and where you can see the glue.
Just wondering if anybody else has done anything like this before.
Old Sep 21, 2010 | 07:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Front Turn Signals
Moisture/dirt is common in the parking light housing. A search will provide info about what others have done.
JamesC
Old Sep 21, 2010 | 08:10 AM
puma1552's Avatar
Why not just fix it the right way by getting a new lens rather than hackjobbing it? GM still sells them.
Old Sep 21, 2010 | 08:29 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
It appears that it's more than just the lights though.
https://www.thirdgen.org/condensation
Old Sep 21, 2010 | 09:10 AM
puma1552's Avatar
LOL, a factory hack job...literally
Old Sep 21, 2010 | 09:58 AM
Bajawoojie's Avatar
As I said, I couldn't get the lens off without cutting into it at all; I'm not sure if its glued or what, but it sure was stuck. So I figured that the chances are I'm going to need to buy new ones either way, so I might as well buy a $5 sheet of polycarbonate and try and makeshift something that looks better than before so that I can spend the money on things that are currently more important to me, such as new shocks and struts.
Old Sep 21, 2010 | 11:42 AM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Or you can go with a set of these if you don't want to go through all that work:
They sell them on ebay, I bought a set for my 89 and they fit and look perfectly!
Old Sep 21, 2010 | 12:45 PM
Bajawoojie's Avatar
Dynodanmanda, thanks for the lead. I had no idea they would be as cheap as $30 for two.
Old Sep 21, 2010 | 08:50 PM
Engine: LSx 5.3
No problem man, just figured I'd help save you some time with these. They look good too, I'll post a pic of mine when I get a chance.
Old Sep 21, 2010 | 08:55 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
I think quality and longevity questions come to mind here, I'm sketch about a lot of ebay stuff though had some crappy stuff before, do they fill up with moisture like the factory ones?
Old Sep 22, 2010 | 12:18 AM
Engine: LSx 5.3
Personally mine do not fill up with water/moisture, but I cannot speak for everyone. I can see why someone would be sketchy buying things from ebay, but i've been very impressed with the quality of all the lights i've bought from companies on ebay.
Old Sep 22, 2010 | 10:42 AM
Bajawoojie's Avatar
If worse came to worse, and they did fill up with moisture, couldn't you just fill all of the holes and make it all water tight anyways?
Old Sep 22, 2010 | 12:45 PM
Apolo's Avatar
Car: Camaro 1987
Engine: V6 2.8l MPFI
This signals fit on a z28 1982-84 models? if not, where i can find the rights?
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
