pics of " pinch welds" please...
Old Jan 22, 2011 | 11:52 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
As the title says. I am in process of trying to "repair" mine but som have been so mangled. I am particurly interested in the area right behind front fender. There is a bolt with a washer, but I don't know which way they need to piont and what they connect to
Old Jan 22, 2011 | 12:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: pics of " pinch welds" please...
that point points straight up, or down, perpendicular ot the floor. Its usually bent flat by somebody jacking pup the car by that point. That usually causes the fender to bulge a little by the door too
Old Jan 22, 2011 | 12:25 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Ya. It was bent in towards body , so I bent it so it is perpendicular but it seemed so much longer then everything else. Do you have pic??
Old Jan 22, 2011 | 12:50 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
It IS longer than everything else due to the huge washer behind the fender bolt, by about 3/8 of an inch... Not sure if I already have a pic posted of this or not.
Old Jan 22, 2011 | 12:55 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Mine was so bent up that it was not attached to anything. Just there. That is why I need pic so I can see how it attches and to what
Old Jan 22, 2011 | 01:00 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Post # 17... https://www.thirdgen.org/forums/body...orth-cost.html
If you need, I can try to get another pic tomorrow as I have to leave for work shortly and won't be back until after dark...
There's 3 layers to the thing, the part that the fender lip sits against, the nut space and nut, and the nut backing. Sounds as though yours may need to be welded back together.
Old Jan 22, 2011 | 01:11 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Yeah. I prob does need to be rewleded. It is ugly. But if you could get another pic that would be great. Also I see you did a lot of work . Did you clean up your floor boards. If so what did you use to cleen up goo around drain plugs, then what to use to seal them back up. I am wanting to out a layer os sound deadening material, but the jute pad sticks to those areas, then I heated them to peel off, but can't get it all up. Too dam sticky
Old Jan 22, 2011 | 02:52 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I haven't even hardly started yet on most of it... Too friggin cold outside and I can't use my new welder without rewiring 2 circuits of the house, which I can't do until the ground thaws...
I haven't touched my drain plugs as they aren't rusted. The squares of tar or whatever it is over them is sticky indeed... I haven't even attempted to get the padding off of them because it's a royal PITA to do. I might end up using either gas or a sandblaster to get them off so that I can install some Dynamat-like material on the floor after I get the Rust Bullet on there after I fix the rust-outs.
Old Jan 22, 2011 | 02:59 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Ya it is pretty nasty. I have got the jute off and a lot of it, but the residue it leaves behind I don't know what to use.
Lanz06
Mar 13, 2019 06:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
buckeyecelt
Sep 24, 2015 05:50 AM
sylentnite
Sep 9, 2015 02:55 PM
gt4373
Sep 9, 2015 10:29 AM
