epoxy primer/sealer for underbody coating
Old May 17, 2011 | 10:35 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Im gonna use this product to paint the underside of my camaro. Im gonna use it in the sealer mixture and im wondeting if I have to top coat it after im done? I was gonna do the underbody and the engine bay. Opinions?
http://www.tcpglobal.com/restoration...pepoprime.aspx
Old May 20, 2019 | 03:22 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: epoxy primer/sealer for underbody coating
If you don't seal the car, or at least prime the entire car so it's the same color underneath the paint, you'll have different pigments unless you do a crap ton of coats. Especially if it's metallic paint. I just repainted my car. Ask me how I know.
Old May 20, 2019 | 03:57 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Links broke but I would ask them what they recommend on the coating. Typically if it will accept a top coat its a good idea to do it. Not all undercoatings can be top coated though.
Old May 20, 2019 | 06:57 PM
BIRD91ZRAG's Avatar
Original post was from 2011...
Old May 20, 2019 | 07:10 PM
Drew's Avatar
Infinite scrolling strikes again.
Old May 20, 2019 | 11:10 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Hrm... It showed up under "New Posts", which is why I commented. Odd.
Edit: Or maybe not? I thought this was the thread I was posting in. I have no idea how it landed here. I knew something was odd when there was only one post. I must've scrolled too far to the bottom and hit the related thread deal. Ugh. Sorry folks!
https://www.thirdgen.org/forums/body...xy-primer.html
Old May 21, 2019 | 01:31 AM
Drew's Avatar
Go to your User CP, click Edit Options... - https://www.thirdgen.org/forums/prof...do=editoptions
Look for this -
Select the radio buttons in the above pic, then click save changes.
Should keep that from happening again.
Old May 21, 2019 | 08:10 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Thanks, Drew! All fixed up.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
armybyrd
Oct 24, 2015 06:59 AM
TheExaminer
Sep 28, 2015 02:28 PM
