How to get into hatch without key
Old Feb 3, 2012 | 03:09 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Had my car repaired at my school shop and the teacher took off with my keys so I can't get into my cars hatch to install my trim and stero stuff, I don't have the hatch motor cover on so how can I get into my hatch?
Old Feb 3, 2012 | 03:32 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: How to get into hatch without key
hammer
Old Feb 3, 2012 | 04:03 PM
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
^^^^LOL....there might be some kind of release that u can get to with a screw driver.....
Old Feb 3, 2012 | 04:53 PM
Engine: L31 350
Know there is but where?
Old Feb 3, 2012 | 10:37 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Originally Posted by evilemokid94
...I don't have the hatch motor cover on so how can I get into my hatch?
Since you don't have the hatch trim panel in place it is a fairly simple matter to release the hatch hook. Lower the rear seat backs and crawl back into the hatch. Unscrew the 10mm screw that attaches the manual or solenoid hatch release from the hatch pull-down motor assembly. You'll see a square hole. There is a lever with a bent tab on it that the manual or solenoid hatch release pulls to pop the latch. Rotate it to the left (counter-clockwise) and the latch will release.
Lon
Old Feb 3, 2012 | 10:45 PM
Engine: L31 350
well i found my keys, they throw them under the passenger floor mat where the hump is, i have everything put back in order now, thank you lon
Old Feb 9, 2012 | 05:37 PM
cbrown's Avatar
Car: 1986 Trans Am
Engine: TBD
Transmission: T5 NWC
I know your problem is already solved, but yes you can open it for future reference. Even if all the trim is in place you can slither to the back, remove the courtesy light cover and find the square hole mentioned above and turn to the left with an appropriatly sized flat head screwdriver or whatever will work. I had to do the same thing with mine.
Old Feb 9, 2012 | 05:41 PM
lonsal's Avatar
Not exactly. You first have to remove the 10mm screw holding on either the manual hatch release or solenoid hatch release before you can access that square hole. Also that 10mm screw is not easily accessed through the hole for the light.
Lon
Old Feb 9, 2012 | 05:56 PM
cbrown's Avatar
Car: 1986 Trans Am
Engine: TBD
my car must be strange because thats all i had to do...the only tool i used was a screwdriver that i pryed the light out with and there was the square hole. just turned it to the left and the hatch opened. really!
Old Feb 9, 2012 | 06:19 PM
cbrown's Avatar
Car: 1986 Trans Am
Engine: TBD
Well, to expand the subject a bit: the key cylinder on my hatchback is very loose...does that mean anything? I was going to replace it but now you got me thinkng that its been tampered with at some point in time???
Gunner242
Dec 25, 2015 04:49 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
formula00ra
Sep 28, 2015 11:50 AM
