sticky black sealant, what is it called? i need more
Old Feb 8, 2012 | 03:09 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Guys im doing a rear deck lid swap, and between the rear glass and the deck lid, there is a sticky rubber/tar like sealant that helps seal the decklid to the glass. I had to remove the old stuff, but im searching and not finding what i need. The automotive stores think i need RTV but i keep telling them, thats not it.
Anyone know what its called and where to get it? im sure its also used on other parts of the car too.
Old Feb 8, 2012 | 03:18 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: sticky black sealant, what is it called? i need more
3M super weatherstripping adhesive
Old Feb 8, 2012 | 03:25 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
where can i get it? "Vatozone" doesnt have it.. i have an O'Reilly's close and a few automotive paint shops close.
Old Feb 8, 2012 | 03:37 PM
Engine: L31 350
Autozone has it, that's where I got mine
Old Feb 8, 2012 | 03:38 PM
Engine: L31 350
Oriellys should have it too, call and ask or even check online
Old Feb 8, 2012 | 03:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Could be 3M Automotive caulking. Bought mine at CarQuest.
JamesC
Old Feb 8, 2012 | 03:55 PM
Engine: L31 350
Same thing really lol
Old Feb 8, 2012 | 04:28 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
This is what you should use. leave the silicone on your engine.
Its also sold in a lil box with about 10" strips but I couldnt find that real quick.
I bought a box of strips 15years ago and use the stuff all the time.. Have resealed about 7-9 rear hatches with it and countless other things.
There is also a adheisive backed foam that should be replaced but is prolly gone..
Make sure you put the sealer in a line just like the factory did so water wont sit inbetween the glass and decklid or drain into your hatch well area.
Old Feb 8, 2012 | 05:55 PM
JamesC's Avatar
Different applications.
TTop's recommendation appears to be on the money.
JamesC
Old Feb 8, 2012 | 06:22 PM
Twin_Turbo's Avatar
That caulking rope was not what was used on mine from the factory. 3M window weld from an applicator gun seems to be what was used. You'll need the window weld and a glass etch primer. Much easier to work with than the caulking rope anyway. To apply, cut a V groove in the spout so you apply a nice tall "comb" of adhesive on the glass.
Old Feb 8, 2012 | 08:18 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
Awesome, amazon had the 3m 08612 5/16" for $12.90. Just bought it, thanks guys
Old Feb 8, 2012 | 11:47 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Body guys call it "dum-dum"
Old Feb 9, 2012 | 12:22 AM
TTOP350's Avatar
You are correct.
My car also had urethane from the factory but I used the dum dum to replace it 15 years ago with great success. The dum dum is much easier to deal with for a at home do it your selfer 1st timer with not many tools.
Old Feb 9, 2012 | 04:34 AM
Twin_Turbo's Avatar
In the U.S. federal law prohibits professional glass installers from installing ANY
auto glass with butyl ribbon that is not also bolted in. A bolted in glass is typically
a quarter glass. This means if they are replacing a windshield it will be a urethane
installation regardless of how it may have been "originally" done.
Now the "Frit Band", that is the black strip you see on late model windshields.
This band does what the clip-on "moldings" did on the older cars. It protects
the bead from sunlight and gives the windshield a cosmetically clean looking
installation. The newer cars no longer have the clip-on moldings so this
is the main reason for the Frit Band so the installation would not look like
SH** (as my glass man put it) as apposed to a clear glass installation with
no moldings.
Clip-on moldings will cover the bead .... but you can simply add
your own Frit Band by taping off the back of the glass and adding one using
Black Pinchweld Primer.
http://www.technologylk.com/images/p...c-CRL950FC.pdf
Scroll down ... page 2 ... BLACK FRIT BAND
The pluses to Urethane vs. Butyl Ribbon.
1st and foremost is safety. (explains reason for Federal Law) The windshield
not only keeps wind out but is also to keep occupants IN...in the event of a
crash. An occupant not wearing their seat belt thrown into a glass held in by
butyl ribbon could easily find themselves and the windshield lying on the hood.
2nd with a proper urethane installation the glass is now a structural part of the
bird cage strengthening the car. Butyl ribbon can not offer this.
Old Feb 9, 2012 | 09:45 AM
TTOP350's Avatar
Correct again. I would never use the dum dum on a windshield esp since urethane came out!
On the rear decklid I don't really see much of a prob with it. The dum dum is covered by the deck lid and the deck lid is also held on with the the trim and 2 masive screws on each side.. lol
Old Feb 22, 2012 | 01:05 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
the original stuff was outlawed by the EPA .it was a butyl rubber compound.call a glass shop and ask for a alternative.as weatherstrip adhisive is not up to this job at all
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dbrochard
Sep 19, 2015 08:13 PM
Randomtask2
Sep 7, 2015 05:06 PM
Stryker412
Sep 7, 2015 09:11 AM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
