Help with key marks.
Old Nov 12, 2000 | 04:51 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I dont know which spot to post this at so I will do both. I just had my car keyed several times. I know that I could get it painted with insurance, but since it has happened more than once I know it will continue to happen so I am not going to paint it. Any way I am sick of looking at them what can I do to get rid of them. My friend said some wax will work because they are not that deep at all. What would you guys suggest? Thanks in advance.
Member of NCTGA
North Carolina Third Gen. Assoc.
'89 Iroc-Z
305 TPI few minor things
5 speed
Lowered 2" and yes it is a pain to drive
Old Nov 13, 2000 | 06:58 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Depending on how deep they are, and how good you are at bodywork, they can be wetsnaded out. If the scratches are only in the clearcoat, then you are OK, anything deeper won't work. If you don't feel confortabel taking sandpaper to your paint(I understand), then some rubbing compound will help. IF you want to wet sand, use 1000 grit and then 1500 grit. Fold the sandpaper into thirds, soak it in water for a few minutes, or use a block and sand lightly while dribbling water from a water bottle. Sand a little with 1000, wipe with a dry cloth and if it needs it, sand more. Be very careful not to go through the clearcoat. When you eliminate the scratch, or can't sand anymore, use the 1500 grit to smooth the 1000 grit scratches. Follow up with some light rubbing compund, then swirl mark remover/glase, and wax.
89 Transam GTA, a few bolt ons
Old Nov 13, 2000 | 12:25 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Thanks for the info but there is no way I feel comfortable taking sand paper to my car. I know someone that is good at body work I may hust ask him for some help.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
