Alternative Detent Roller Replacement
Old Aug 3, 2012 | 11:59 AM
bobs's Avatar
Car: 87 Iroc
Hey guys I came up with a alternative way of replaceing your worn out door hinge detent roller. Rather then waging the all out war of trying to remove that pin.
1. Remove the roller. These can be cut off or if its like mine it will fall off. Don't damage the pin shaft.
2. Center punch and drill a pilot hole in the center of the shaft. A drill press will go a long way to making sure it is centered and strait. I used a #30 drill bit.
3. Carefully grind to head off. The idea is to take only the head. This will leave the pin with its original exposed length and a nice flat surface. If you cut the pin just below the head you will be removing a saw blades worth of material from the pin and it will probibly be to short.
4. Now open up the hole with a #25 drill and carefully thread it with a 10-24 tap. You want to be at least a 1/2 inch deep. Work slowly as the last thing you want to do is break the tap. That will surely involve some swearing.
5. Slide a new detent roller on the pin making sure the large bushing is facing down.
6. Top it off with a #10 washer (I used 2 as they were very thin) and 10-24 x 1/2" button head screw. I used stainless steel hardware available from Lowes.
This really only took about 15 min worth of work and is pretty simple to do. Again just work carefully. Cheers.
Attached Thumbnails Alternative Detent Roller Replacement-2012-07-30_16-42   Alternative Detent Roller Replacement-2012-07-30_19-07   Alternative Detent Roller Replacement-2012-08-03_12-16
Old Aug 3, 2012 | 12:00 PM
bobs's Avatar
Car: 87 Iroc
Re: Alternative Detent Roller Replacement
Finished Hinge
Attached Thumbnails Alternative Detent Roller Replacement-2012-08-03_12-19
Old Aug 3, 2012 | 06:46 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Wow, thank you for that information.
Old Apr 13, 2016 | 12:37 AM
Jacques101's Avatar
Car: 1984 &1987 Firebird, 1991 GTA
Engine: 5.0(84) , 5.7L LT1 (87),5.0(91)
Transmission: Automatic
Axle/Gears: 3.23;3.42;2.73
Where did you get the new detent roller? Does the ones off the 1967 to 69 repair kit have the same OD?
Old Apr 17, 2016 | 12:21 AM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
subscribed
Old Apr 26, 2016 | 06:45 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Originally Posted by punkmaster98
subscribed
Old Apr 27, 2016 | 09:44 PM
Jacques101's Avatar
GM #20058035
Just found a set of rollers on eBay… Hope this helps
Old Apr 27, 2016 | 11:24 PM
Jacques101's Avatar
This link was also left by Lonsal on a different thread I inquired about purchasing Detent rollers
http://www.top-downsolutions.com/ind...product_id=291
Old Jun 11, 2022 | 07:18 AM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
I like this salvage method!. This would even be a good modification to do before installation of a new hinge half. Only simple replacement procedure needed for any future repair if they get sloppy again.
Thanks for posting this,
M
Old Jun 13, 2022 | 02:27 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
So...basically you cut the top of the original pin off, remove the roller, then drill / tap a hole into the actual original pin?
junkcltr
Aug 2, 2019 11:12 PM
dutch930
Sep 11, 2015 06:58 AM
Dialed_In
Aug 20, 2015 01:45 PM
