can this paint be repaired?
Old Oct 2, 2012 | 01:50 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
I would like to just temporarly fix this paint if that's possible until I can afford a new paint job. Mainly just clear has come off and the sun baked the paint. Any help is appreciated.
Old Oct 2, 2012 | 07:05 PM
zz4IROC's Avatar
Car: 1988 iroc
Engine: 350 forged crank, pistons, 11.5:1
Transmission: t-5
Axle/Gears: 10 bolt 3.73
Re: can this paint be repaired?
To properly fix peeling clear, the panels should be stripped. Best off leaving it alone and waiting until a paint job is in the budget.
Old Oct 3, 2012 | 12:22 AM
86F.BiRD's Avatar
Car: 1986 Pontiac Firebird Base
Engine: SBC 350
Transmission: Borg Warner T-5 World Class
Axle/Gears: 4th Gen Rear with 3.73s
If it was me, with my very very low budget, I would try to peel all of it off and either leave it flat or spray paint a clear coat. But thats just me.
Old Oct 3, 2012 | 11:46 AM
Gsoleski's Avatar
Car: 1984 Z28
Would I be able to wet sand those spots to get it all off? then spray on a clear coat? Or will it look flat still
Old Oct 3, 2012 | 06:43 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
You can wetsand to feather in the clearcoat edges and then spray clearcoat (careful to not sand through the paint), just don't expect it to be durable or match
Old Oct 4, 2012 | 02:24 PM
BAMA92's Avatar
Car: 92 Camaro Convertable/ 68 Camaro SS
Engine: 305 TBI
Transmission: Auto 700R4
Axle/Gears: 86 TransAM posi rear. 342 gears
You can not wet sand that. your first answer is the correct one. You do not sand base coat. it will mess up the paint and will show if you respray clear over it. It sucks but all GM cars did it back in those years. If you are just die hard on trying something, Just get some clear in a can and spray over it.... but if you sand on it first then spray clear on it, the scratches will show.....
Old Oct 4, 2012 | 03:38 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
I had a long response to this, but then I realized you didn't even read what I wrote so I gave up
Old Oct 10, 2012 | 12:46 PM
jbalzola's Avatar
Car: 1984 Pontiac Firebird
Engine: none atm
Axle/Gears: 3:73 zexel torsen
I actually just had the same problem on my truck, I used 1000 grit wet sanding paper and sanded the hood and roof of my truck. I sanded the clear to feather the edges and I sanded the exposed paint to smooth it out. I cleared both areas and I see no signs of scratches under the new clear. Just be delicate when sanding on the paint. I picked up all the materials for about $100
scottmoyer
Sep 7, 2015 07:06 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
mrdevontay
Sep 2, 2015 08:04 PM
