Door spring ??
Old Nov 16, 2001 | 07:38 PM
steel1212's Avatar
Door spring ??
Hi!
I just got done putting in lower pin+bushings on driverside door. How can you get the spring back in without that special tool. Any ideas would be great!
STEEL1212@AOL.COM
87' 2.8 Sport Coupe
Old Nov 16, 2001 | 09:15 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Check out www.3rdgensolutions.com the part# for the tool is listed there.
Old Nov 19, 2001 | 12:27 AM
formula88bird's Avatar
It not vary safe, but I put mine in a vise, pinched it closed, and used 4 wire ties to hold it. Put it in place then cut the ties. Be vary carefull.
305TBI(LO3)
K&N filter
Old Nov 19, 2001 | 03:05 PM
steel1212's Avatar
Thanks,
I went to a local bodyshop and the guy did it in 3min. for me free-of-charge!
STEEL1212@AOL.COM
87' Camaro 2.8 Sport Coupe
Old Nov 21, 2001 | 12:44 AM
Blaze of Glory's Avatar
Car: 92 Firebird
Engine: 3.1L V6
did replacing that fix the sag?
Old Nov 21, 2001 | 10:26 AM
steel1212's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Blaze of Glory:
did replacing that fix the sag?</font>
HI!
For me it worked . The bottom bushings over time wears so the pin gets loose . I got a buddy to lift the end of the door up and down while I watched to see if it was a top or bottom hing problem . Bottom pin had play in it. I had about a 1/4" of play but it wasnt causing any bad problems so I fixed it at a good time. Now if you see that the top hing has play or the holes that the bottom hing bushings fit in have inlarged then you have major hing repairs. Do a search on thirdgen for DOOR HINGES you will find lots of info.
I had a few problems such as getting the door spring in (went to bodyshop for that) and I still didnt get my door alined just right yet.
STEEL1212@AOL.COM
Old Nov 21, 2001 | 11:40 AM
steel1212's Avatar
TESTING TESTING 1 2 3
STEEL1212@AOL.COM
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=8023.
Old Nov 21, 2001 | 01:15 PM
89 4Mula 350 Tbi's Avatar
Yea these hinges suck
my door was sagging and it was because of the bottom hinge and bushing so i replaced it and it still sags. I found out why but dont know how to fix it. There are the 2 bushings you get in the kit and you put them in the part of the hinge that goes on the a piller but the holes on the hinge thats part of the door are worn too so i have no clue what to do i think i'm gonna have to fabricate some busshing NE ideas guys.
Old Nov 21, 2001 | 01:58 PM
steel1212's Avatar
TEST
Dont mind me trying to get a link working
STEEL1212@AOL.COM
www.thirdgen.org/rides/index.tgo?action=view&rideid=8023 .
Old Nov 21, 2001 | 02:03 PM
steel1212's Avatar
S U C C E S S
STEEL1212@AOL.COM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tglennon11
Sep 23, 2015 05:30 PM
billybob6110
Sep 23, 2015 01:30 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
SG91camaro
Sep 5, 2015 10:27 PM
