Possible Misaligment
Wanted to say first, Ive been a lurker/reader here for a little bit and decided to sign on up here at TGO seeing how Im a proud owner of a 1990 Iroc-Z. To the point, ever since I bought this car, Ive always noticed this but never really delved into why its like this up until now since Im wanting to purchase SFCs and get everything locked in place per-se. Passenger side door and fender seems to not align with each other the way the driver side does. Backstory, this is an all original 1 owner car that Ive purchased with 70,000 original miles and was garage kept its life and its all original with no accidents and still essentially a brand new car from a Barret Jackson auction.
To the point, the passenger door closes fine, no binding, no sagging, weatherstripping and etc is perfect. Its merely just the way it looks. To me, the door is sitting inwards more so, or perhaps the fender is sticking out to much? The driver side is lined up, nothing sticking out and the center pinch is a solid line all the way down. It seems like the passenger side the rear of the car is lined up, just no the front.
To me, its minor, its mainly looks because the door closes fine and doesnt sag or bind, my issue is, with getting SFC (Im getting inners & outers) and locking everything in and stiffening her up, is this something Id want to get straightened out beforehand? Will this be an issue before or after SFCs?
Thank you & sorry this is a long post, Im not the best at explaining things.
Car: 1992 Z28
Engine: 383
Re: Possible Misaligment
Look under the car by the door fender joint area. Most likly someone jacked the car up on the lower fender mount and this causes the fender to bow out from the door. Only way to fix it is remove the fender straighten out the lower mount on the fender and the body and reinstall the fender realigning it with the door. Very very common problem with these cars.
I appreciate your reply and Ill definitely crawl underneath her and have a look. I tried to upload pictures of it but I guess since Im on mobile its not wanting to cooperate.
https://imgur.com/a/NjZHwQ1
Car: 1992 Z28
Engine: 383
I looked at your pictures and that is exactly your problem. Someone jacked the car up by the fender so you will need to fix what I described.
Looked and sure as hell, youre absolutely correct, its bent. I know I myself havent done it. Thanks from here on TGO, Ive learned quite a bit specially jacking it up and amongst other things. Now, if I leave this be for the mean time, would it affect anything if I add SFCs? Surely not perhaps, but Id rather do things right the first time then have to go back and have to fix things and the whole unibody thing is new to me, specially this is my first Camaro.
Car: 1992 Z28
Engine: 383
It wont affect the sfc install at all. Make sure when they are installed the car is on a drive on lift so the car is settled on the suspension and not on a post lift or jack stands
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
This is wrong, you dont want the car on the wheels as the whole problem with these cars is they sag in the middle, with the car on a lift the body returns to the as built posture. I did mine that way and the door close perfect now and the car drives like its alot more solid. you want the front and rear to droop when you install them so the connectors are under tension when you put the car back on the ground.
Car: 1992 Z28
Engine: 383
Engine: LB9 305
No need for me to do research, the cars sag and twist , setting the car on jackstands at the frame sections helps load to car back to original. you do yours like you want, but mine is perfect now. before the doors rubbed on the striker post. now thy close perfect. Ive been messing with third gens since the 80s , I know what works and what doesnt.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
It depends on how sloppy the body is. A high mile car that's been driven hard can sometimes twist all out of shape when it's supported by the jack/lift points. Ain't no way I'd weld in connectors trying to hold the body in that position.
If the car is on all four wheels and the body gaps are good, imho that's how it should be when the connectors get welded in. I'm not saying it won't work the other way, just saying which way I think is the better way to do it. My car has no squeaks or rattles and has some of the nicest body gaps you will find on a 3rd gen.
Also, the passenger fender was often bent out before they even left the dealer when new. A friend of mine bought a new '88 RS with the fender gap problem. He made the dealer fix it before he took delivery.
RoadRocket L98
Aftermarket Product Review
Jan 22, 2001 07:13 AM
STL1994
Nov 15, 2000 07:04 PM
