WINDOW SCRATCHES
Old Dec 23, 2020 | 02:00 PM
gt4373's Avatar
Transmission: 5-Speed Manual
WINDOW SCRATCHES
What's the Best Way/Product To Use To Remove Light Scratches On The Drivers Door Glass From Cranking The Window Up And Down For 36 Years.
Sorry About The Window Reflections
Old Dec 23, 2020 | 03:38 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: WINDOW SCRATCHES
Buy a new window.
Old Dec 23, 2020 | 04:22 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
I tried a couple different products to remove scratches similar to this and haven't found any that work.
I agree with okfoz - only way to fix is replace the window.
Old Dec 23, 2020 | 04:38 PM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
I remember watching a restoration show years ago, maybe from the guys at Legendary Motorcar. I seem to recall them using successive finer grades of steel wool, but not the hardware store stuff. They used it on old Ferrari's and that sort of thing where buying a new window wasn't an option. Not sure where you find that fine a grade.
Old Dec 24, 2020 | 07:47 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Give some Cerium Oxide polishing compound a try; the Google will locate a source for you.
Old Dec 24, 2020 | 07:53 AM
stron3's Avatar
Car: 87 Camaro Z28
In my experience the products out there to remove even fine scratches from glass are labor intensive and messy and you run the risk of distorting the glass if you get overzealous. The end result is usually not worth the trouble.
Old Dec 24, 2020 | 02:12 PM
erik69&85's Avatar
If only i could find new glass.... been looking for a drivers side for years.... no one actually has it.... been watching Craigslist....only passenger doors come up...
Anyone know of a supplier?
Old Dec 25, 2020 | 08:20 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Years ago I had to replace a passenger side. Just brought car to a car glass shop and they put new one in same day.
Old Dec 25, 2020 | 10:24 AM
okfoz's Avatar
Call around to local Glass shops, Someone will have a source... Hawks should have something as well.. They would be used, but that would probably be the best you can do... There were millions of them made. Finding a perfect one might not be in the cards, but you might find one that is really good.
Keep in mind, IF you have a Norwood car, you have PPG Glass, and Van Nuys has LOF Glass
John
slia67
Apr 20, 2009 02:38 PM
TraviZ
Northern California
17
May 22, 2005 02:22 AM
breathment
Jan 23, 2003 04:40 PM
82CamaroZ28
Jan 15, 2002 01:41 PM
