rear brake lines for 92 camaro
Old Nov 2, 2002 | 08:11 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I purchased a complete Baer brake kit from Year One. The front track system comes complete with rotors,calipers and front brake lines. The rears only come with a 12" rotor, and I have to use the OE caliper and brake lines. While I'm installing everything I'd like to replace the old rear brake lines also, but I don't know if anybody sells just rear lines? If not, does anybody know the length and what pieces are on the ends? I can go to the local speed shop and have them made out of what -3 or -4 AN line?
Any help would be greatly appreciated.
Old Nov 3, 2002 | 01:41 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If you're talking about the hard "steel" lines on the rear axle:
http://www.finelinesinc.com/
http://www.inlinetube.com/
Also, AndyZ28 quite possibly could hook you up.
HTH...Ed
Old Nov 3, 2002 | 06:06 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
No I'm talking about steel braided replacements for the worn out ones that connect to the caliper.
Old Nov 3, 2002 | 08:41 PM
MdFormula350's Avatar
i know earls makes steel braided brake hoses to replace stock ones!!
Old Nov 3, 2002 | 09:04 PM
ebmiller88's Avatar
Yeah..go with Earl's lines. Good quality pieces. If you end up just using the rear lines, you could unload the fronts very easily. I'd take 'em.
Ed
Old Nov 3, 2002 | 10:01 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Re: rear brake lines for 92 camaro
What year is the car? Was it originally equipped with rear disc brakes?
Thanx,ANDYZ28
Old Nov 4, 2002 | 05:18 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
92, and yes it came from the factory with rear brakes. non/1LE.
If nobody makes just a rear kit, I'd like to just find out the length of the stock ones and just make some up. There is a place close by that is pretty good with steal braided line. Just tell him the length and what connectors you need and your golden.
Old Nov 4, 2002 | 05:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
For anyone else that wants stainless steel tubing (not the flex hoses), http://www.classictube.com is another tubing place. Not sure about the other two mentioned, but at classic, you can get either OE steel or stainless. You can also buy "just" a rear axle kit, with the two hard lines.
Old Nov 7, 2002 | 08:57 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I guess I could be picky but I would call baer and get the rear lines.. when you buy kits directly from them that is an option I am sure they have them separately..something about sticking with the same manufacturer that gives a warm fuzzy.
Old Nov 7, 2002 | 06:42 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
I did call BAER today and they said, they don't carry stock replacement lines, they only carry lines for there touring,pro touring etc.. kits. Baer or Year One, which ever designed this 4 wheel disc kit thought that the rear OEM brake hoses are adequate enough for the 12" rear rotors I received. I guess I can just go to a dealership and purchase a OEM rear brake hose and have it duplicated at the speed shop, unless sombody here knows the specs???
Old Nov 7, 2002 | 09:35 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
I may be wrong but don't some of the later model f-bodies already have the pbr rear setup? if so the Baer track lines will hook right up.. if not go with Earls, keep the extras as spares or sell them on the board if you want to unload them..
IMO I would not however go to a speed shop to get them duplicated.. something there sounds a little too hack and stick for me.. especially with the brakes.. good luck!
Old Nov 8, 2002 | 12:38 AM
Benny's Avatar
I believe the '89 to '92 J65 cars came with the PBR rear brakes.
Old Nov 8, 2002 | 08:37 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
It's starting to look like I'm going to have to go with the Earl's.
Thanks for everybody's input.
Old Nov 8, 2002 | 11:45 PM
Benny's Avatar
The earl's are excellent, I believe your application will come with the front and back. The back is 3 piece, one for each wheel and also the center hose that the hard lines fit into.
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
