1LE front brakes installed
Old May 11, 2003 | 12:28 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I finally put on my front 1LE brakes. Buying a recip saw really helped speed up the process. I got my tap from Sears incase anyone is planing on modding the spindles themselves. I put on my 15" gold crosslace wheels and there is plenty of clearance between them and the brakes.
Old May 11, 2003 | 12:29 AM
before:
Old May 11, 2003 | 12:30 AM
After:
Old May 11, 2003 | 04:24 AM
englishz28's Avatar
Car: Z28
That looks awesome!!!!!!!!
Great job!!
I bet you can't wait to try em out.
Cheers
Phil
Old May 11, 2003 | 03:48 PM
Thanks. According to the Baer Brakes site, new rotors have to be seasoned for 5-6 days before pad bedding. So I'll looks like it'll be a week before I can really find out who well they work.
Old May 11, 2003 | 04:30 PM
CrazyHawaiian's Avatar
Car: too many ...
What was the total cost?
Old May 11, 2003 | 04:39 PM
I think around $800. I bought most of the parts 2 years ago.
Pic with the wheel on.
Old May 11, 2003 | 04:40 PM
Another
Old May 11, 2003 | 09:53 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Yes you should wait about a week of normal driving before you test them out. The brakes need to be broken in.
Old May 12, 2003 | 12:20 PM
Parrydise7's Avatar
Did you change the m/c and p/v? Be careful when you try those brakes out, just in case. I couldn't lock up the brakes after the conversion until I changed the m/c and maybe the p/v (it's been awhile since I did the swap).
Old May 12, 2003 | 06:38 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You'll love the improvement!
Take it out and do 5 or 6 real good "panic stops" and you'll be good to go, You just have to get that glaze off the pads and rotors.
Congrats!
Ed
Old May 12, 2003 | 10:00 PM
I have rear drums so I already had the MC. I'll wait to put in the 1LE Prop valve until I put in my LS1 rear brakes.
Old May 13, 2003 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Justin and Ed,
I purchased Spohn's 1LE kit and all the associated parts needed: combo valve and M/C, Earl's lines, etc. I've completed the spindle mod (hacksaw with a new blade--wasn't that bad). While I'm in there, I intend to replace the a-arm bushings with Prothane (also from Spohn). Any suggestions that will save me time or effort would be appreciated.
JamesC
Old May 13, 2003 | 07:43 PM
If your done cutting the ears off and tapping, the rest is just easy assembly.
If your putting in new a-arm bushings, might want to put in new ball joints too.
Old May 14, 2003 | 12:01 AM
ebmiller88's Avatar
Yep, do the ball joints while you're at it. You might as well replace the little bump stops on the A-arms, too. Mine were just falling apart. Looks like you have it all ready to go. Please post pics of your LS1 rear brakes, I'd like to see them.
Ed
Old May 14, 2003 | 12:26 AM
Will do. Still need to get some misc bolts and fab up a e-brake bracket.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
