... for whether the rear brake lines on an'85 are the same as a '96.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Sorry,
I've searched and looked for whether the rear brake lines on an'85 are the same as a '96.
I upgraded the rear brakes to LT1 and have the LT1 lines up to the "T" fitting.
The "T" fitting is a stainless steel Earles part for an '85, but the LT1 lines bottom out on the "T" fitting and I don't believe they are seated down properly. The Earls "T" fitting has a really deep recess for the brake lines and is where I think my problem lies.
Has anyone run into this?
Any help is appreciated.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
It will depend on the "T" fitting, whether they are bubble flares or inverted flares. Third gen lines are (usually) metric bubble flares, 4th gen lines may be different. I have a set of Earl's lines for a '98 up LS1 car and the "T" fitting is an inverted flare fitting.
Ed
Ed
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Originally posted by Scorpner
Thanks, so I need to find out if '96 F-bodies have inverted or bubble flare ends.
I suspect Earl's will make him buy a whole kit, they don't like to separate lines or sell in pairs..I've tried that.
If you (Scorpner) still have trouble, call me or PM me. I have a lot of Earl's lines on hand and may just have what you need.
Ed
Ed
Ed
Ed
Engine: V6, V8
I'll try talking to someone from Earls since I already have one of thier lines. If that doesn't work out, I'll give EB Miller a call. Thanks for the offer.
EB, can you explain how to tell the difference between an inverted and a bubble flare?
Thanks for all the input from everyone!
buble looks like this /\ where as inverted looks like this \/
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
I used the axle hardlines from a 1997 Camaro on my 1983 T/A, and the flare was the same, on both, at the block on the axle.
The flare was inverted.
Leon.
Leon.
Engine: V6, V8
I think the problem is the aftermarket "T" fitting. I haven't had time to call Earls yet.
Thanks for confirming.
