ls1 brake line adapters
Old Nov 13, 2006 | 08:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
hey just picked up a set of ls1 rear disc to swap onto my car, i know the brake lines have the wrong flare and i have heard there is an adapter i could buy to remidy this, anyone know where to get it? thanks
Old Nov 13, 2006 | 10:58 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Napa but you'll have to go through the catalog.
Ed
Old Nov 14, 2006 | 05:28 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I just did the LT1 changeover on my rear and got a set of hoses with regular brake line thread and changed them at the banjo fittings. Works great.
I don't remember what the parts guy used, but I think they were just older GM hoses.
Ron
Old Nov 14, 2006 | 06:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
hoses? i was under the impression that the hard line runbs right into the rear calipers... am i wrong?
Old Nov 14, 2006 | 07:35 PM
ebmiller88's Avatar
Yep...each caliper will have its own flex hose, you'll have a total of 5 flex hoses on the car now.
Ed
Old Nov 14, 2006 | 08:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
hmmm interesting, so i quess i will try and get a set of ss braid to match the set i have on the car now, but i will be sure to get the right thread and flare for the old style double flare, this seems kinda simple thanks!
Old Nov 15, 2006 | 01:25 PM
ebmiller88's Avatar
If you need rear braided lines, LMK...I have a ton of Earl's lines on hand.
Ed
Old Nov 15, 2006 | 09:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
hey ed, if you have ones that will work for me i would love to get a set. tey would have to fit the ls1 rear calipers and recieve the old sytle double flare. thanks
Old Nov 15, 2006 | 10:24 PM
ebmiller88's Avatar
Yes, the lines I have will work. I'll send you a PM. Also, what kind of rear hard lines do you have: disc or drum? If you have drum rear lines you'll need to shorten them or swap them out for disc lines.
Ed
Old Nov 16, 2006 | 05:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
hey ed, i have a drum rear with drum brake lines, somewhat recently replaced with ss hard lines. i think i can shorten them, might be a bitch though.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
