Correct M/C for disc/disc setup?
Car: 1934 Ford Roadster
Engine: 350 CSB
Will this Master cylinder work for a front- rear disc setup?
http://store.summitracing.com/partde...104460&FROM=MG
Engine: 350 CSB
I know that, but when I browse other car part stores, the M/C for third gen Camaro has the same stock numbers for both disc/disc and disc/drum setups, so my question is;: Do all Camaro M/C's function on both types of setup?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The only difference between the disc rear and drum rear master cylinders is the pedal effort and travel. Either one will work.
Engine: 350 CSB
That's what I thought, but I wanted to hear it from one of you guys to be sure.
Thank you for your reply!
By the way. Do you know if these M/C's have the same bolt pattern as the older "typical hot rod" cast Corvette master cylinders?
Like this:
http://store.summitracing.com/partde...9+&appfilter=1
Because if it does, it will be possible to conect the newer Camaro M/C to hot rod boosters like this one:
http://store.summitracing.com/partde...5&autoview=sku
Like this:
Engine: 383 Carb
Transmission: 4L60
Even if the bolt pattern is the same, the fluid connections are metric on most thirdgen master cylinders.
Car: 1985 IROC-Z
Engine: 350 CID (exchanged from a Corvette)
Transmission: 5 speed (stock)
Recently I was trying to get master cyl. and visited an on-line shop and noted that the kit number change with the type of rear brake system.
ACDELCO PN are different
ACDELCO Part # 18M313 {#18030555}
CYLINDER,BRK MAS DURASTOP; RR DRUM BRAKES-WITH POWER BRAKES; 24.0 & 31.75MM CYLINDER BORE
ACDELCO Part # 18M314 {#18030556}
CYLINDER,BRK MAS DURASTOP; RR DISC BRAKES-WITH POWER BRAKES; 25.4 & 36.0MM CYLINDER BORE
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
What is the difference? I'm swapping a 9 bolt with 12" PBR discs into an '89 Formula with rear drum brakes. What differences can I expect to fin in pedal effort and travel?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sean, if you currently have drum brakes, you have the correct M/C for the rear disc swap.
This from the mighty Aperion:
https://www.thirdgen.org/forums/susp...fferences.html
Engine: L03 305 TBI
Linson
Sep 21, 2015 01:08 PM
MikkoV
Sep 9, 2015 04:25 PM
