pulling to the right
Old Jun 25, 2013 | 05:49 PM
lv2bnmyz's Avatar
Car: 91 & 92 Z28 Vert
Engine: 91 305 92 383
Transmission: TCI Streetfighter 700r4
Hitting the brakes and the car will pull hard to the right. Sometimes harder than others any quick ideas on what to check or got a happen to me solution. Thanks.
Old Jun 25, 2013 | 06:20 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: pulling to the right
The common issue is collapsing hoses.
JamesC
Old Jun 25, 2013 | 06:34 PM
Whichever side it pulls toward, check the other side first.
Old Jul 13, 2013 | 02:28 PM
Crusherfied's Avatar
Axle/Gears: 9 bolt disc 3.27
I'm having the same issue. When you say a "collapsed hose" the first thought that comes to mind is flattened rubber line, is this what you mean? I've seen rubber lines crack, but not flatten. Or do you mean a hard line has been crushed flat somewhere?
Old Jul 13, 2013 | 02:30 PM
JamesC's Avatar
The line fails internally.
JamesC
Old Jul 13, 2013 | 02:56 PM
JamesC
Ok, I see. The line fails inside and the fluid can't get through very good. Wish I knew this before I bought and installed new front calipers.
Old Jul 13, 2013 | 05:23 PM
Why is this a concern?
They're SO CHEEEEP, it's like, you oughta replace em every time you take em off for ANYTHING. Life is too short to worry about stuff like that.
Old Jul 13, 2013 | 08:29 PM
Oh, I agree! It's just that when TIME and Money and in short supply in day to day life, anything extra can get to be a bit much. Sometimes the old adage "if it ain't broke, don't fix it" has a nice ring to it.
Having new calipers is good peace of mind, but.....now I have to jack the car up, again, and then remove the wheels, again, put the new lines on, then bleed the air out, again.....just wish I could have figured it out the first time so I wouldn't have to repeat everything.
One thing I did do when I did the calipers was to repack and tighten the wheel bearings while I was at it, they sure needed it, and that took car of some of the weird noises I was hearing while driving.
Just so you know, this car is new to me, but it hasn't been on the road in many moons, and I just started driving it a few weeks ago, so I'm trying to iron out all the wrinkles. Since it is a project car for resale, I want to do things right, but also keep the budget and time factor to a minimum.
Old Jul 13, 2013 | 09:22 PM
Well, next time you'll know... just the fluid you put in there, costs near as much as the calipers. They're so cheep, it works the same way like we all choose not to re-use toilet paper or something, even if it doesn't seem "worn out" yet.
When you replace your timing chain, put a new water pump on. When you're replacing your tires, put new valve stems in. When you take your calipers off, .... you do the math.
wigmobile
Feb 26, 2025 02:56 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
sylentnite
Sep 9, 2015 02:55 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
