Flynbye Performance S10 hubs with ABS
Old Sep 10, 2018 | 06:04 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Will this kit allow me to put a wheel speed sensor on the front of my car?
I assume it's a drop-in replacement for my existing hubs that have been modified for use with C6 Corvette brakes?
http://www.flynbye.com/catalog/i230.html
Old Sep 10, 2018 | 09:27 PM
Drew's Avatar
Re: Flynbye Performance S10 hubs with ABS
Wouldn't the wheel sensor on a S-series truck still be mounted on the spindle? I'd think the hub would be the reluctor wheel, but without the corresponding calibrated mounting location for the sensor, I'm not sure how well it'd work. I'd say email Ed... But yeah...
Are you trying to ABS the speed scrubbers?
Old Sep 10, 2018 | 09:33 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I think the speed sensor is mounted to the dust cover.
I'm thinking about traction control using my Holley HP EFI.
Old Sep 10, 2018 | 09:47 PM
Drew's Avatar
Hmm... would TC really need the front input? Durn new fangled, voodoo witchcraft electrons zipping back and forth trying to drive the car better than the driver... Dang ol black magic. Tell you what.
Kinda wish I knew more about next gen tech, kinda.
Old Sep 10, 2018 | 10:42 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I want this to be adaptable to road conditions so I would need to know difference between front and rear wheel speed. Honestly, I'm not even sure I can set up something like that in HP EFI software. Maybe I should look at that first.
A basic option right now is that I push a button on the steering wheel and the system looks at a timing retard table by RPM and MAP. Let the button go and it goes back to the usual tune. Not great, but maybe better than me trying to pedal the throttle.
A third option is I look at the rate of change of driveline speed and reduce power if the rate spikes above normal. This is what the Davis Technologies traction control does. I'd have to convert my transmission to a Viper tail housing with a Hall Effect speed sensor if I want to home-brew something like that on my own.
Old Sep 11, 2018 | 07:35 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Somehow the Holley setup only uses the driveshaft speed for the traction control. I was looking into it, but It isn't something I need.
Old Sep 11, 2018 | 06:17 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Holley traction control is a $600 - $1,000 Davis Technologies unit that is integrated with the Holley ECM. A reluctor ring is clamped to drive shaft yoke.
I can set up a custom table with front and rear speed as the two axis and timing retard populating the table. The location in the table is really just the difference between front and rear speed. Not highly elegant but not too bad either.
Maybe I need to read up how the ProEFI traction control works and see if it sparks ideas.
Old Sep 12, 2018 | 07:34 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Where does the EFI system get is Vehicle speed from? It would know the expected RPM of the driveshaft with gearing/RPM input. However, if the tires brake loose the driveshaft and engine RPM all go with wheel speed. It has to be comparing this to another "known" speed. Since I am considering changing my stock EFI over to a system that can be easily tuned (way down the road), I want to see what you find out. Having traction control for is a nice feature for normal driving.
Old Sep 12, 2018 | 08:50 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The Holley system doesn't get a VSS input, not to say you can't add it, but the system doesn't use it
Old Sep 12, 2018 | 11:25 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Interesting, I am looking forward to someone posting up how it uses the driveshaft speed for Traction Control.
Old Sep 12, 2018 | 09:24 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I already know how to drive normal. Everything I'm talking about is "power" traction control to make the car go faster under high throttle. I'm not sure any of these systems are sophisticated enough or tuned for slippery roads.
The Davis Technologies kit (Holley) comes with a speed sensor and a reluctor ring that gets clamped onto the driveshaft yoke. The video below gives you an idea how it works. Don't go past 4:00 min unless you like really annoying sounds.
Old Sep 12, 2018 | 09:35 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I'm not terribly interested in that system though. If I'm going to spend $1000 then I'd rather have a set of lightweight hubs that help the car ride and handle better. I already have transmission speed signal fed to the ECM so that gives me rear speed. Adding a front speed sensor will allow me to cobble up my own traction control using custom 2D tables in the Holley software.
I could even do a very basic traction control right now with just my trans speed signal but it would probably over compensate and be jerky.
Old Sep 13, 2018 | 08:55 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
https://www.youtube.com/watch?v=xqeo48caBxs
I look at it differently. Normal driving is when I leave on all the "electronic helpers" in my Challenger during my normal daily drives. For the unknown on the road like idiot drivers forcing the need for emergency maneuvers. Under more controlled conditions (light traffic late in the evenings, back country roads, or even better at the track), you can push the car closer to the limit and turn off some of the electronics.
Informative video... I am very interested in seeing how this develops. I have seen a lot of new model engine/trans swaps, suspension upgrades, and a lot of other adaptions of modern cars to older cars, but don't see many adapting safety technologies.
Old Sep 28, 2018 | 04:54 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I can tell you right now that the biggest hurdle here is getting FlynBye Performance to answer the phone or return a call. This is getting ridiculous.
vorteciroc
Aftermarket Vendor Review
60
Sep 7, 2018 09:35 AM
dhirocz
Brakes
Dec 4, 2012 11:07 PM
white1991rs
22
Nov 29, 2012 06:39 PM
GTAman
Aug 23, 2012 08:33 PM
skinny z
Feb 8, 2011 06:32 PM
