Simple Brake Upgrade - 1991 Formula
Old May 2, 2023 | 06:40 PM
Scotty54's Avatar
Car: 91 Formula
Engine: 2005 LS2
Transmission: 2002 T-56 6-speed
Axle/Gears: 4.11
I have a newly-acquired bone stock Formula (and want to keep it that way) but I do plan on some mods that are not obvious and can improve performance. I do not drive the car hard and don't intend to but I find the brakes only fair for a 4-disk setup. I know there are lots of pricey options but I think a high quality brake pad and improved disk will enhance the braking enough to satisfy my needs. I don't think I need to consider replacing the calipers at this point. I have bled all 4 corners with marginal improvement, pads have some meat remaining but with less than 40k miles figure all components are original.
Q1 - is my lackluster braking common among 3rd gens?
Q2 - any suggestions for quality pads and rotors for improved performance?
I am new to the 3rd gens so any suggestion will be appreciated. Thanks in advance!
Old May 2, 2023 | 07:58 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Simple Brake Upgrade - 1991 Formula
Q1: Yes
Q2 Akebono pads are pretty good
Q3 Id look into LS (98-02) brake upgrades for al lfour corners
Old May 2, 2023 | 08:11 PM
Our cars' brakes were PHENOMENAL in their day. Same brakes as came on a truck or giant land yacht, but our cars were MUCH smaller and lighter. We all thought they were STATE OF THE ART.
Fast forward to 2023.
Those brakes SUCK nowadays. A soccer mom minivan will make you rear end her. (her minivan that is) So, yeah. The biggest problem is the tiny rotors; BUTT, the wheels that our cars came with, only allow just so much brake inside them.
If your car is 88-back, it ahs the CRAPPY cast-iron rear discs. That GARBAGE is the kiss of death. Those POSs are worse than drums, BY FAR. At least you can improve drums sometimes by adjusting them. But those old D-M discs... hopeless.
What year is your car? Are your rear calipers smooth and cast-iron, or are they finned and aluminum?
Old May 2, 2023 | 10:24 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
It's a 91 Formula 350
Old May 2, 2023 | 10:41 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
I'm satisfied with my AC Delco rotors and AC Delco semi-metallic pads. I do have the '89+ PBR rear calipers which helps I suppose.
Old May 3, 2023 | 01:52 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Some 350 and 305 tpi 5speed cars . May have gotten rear drums in 91 due to the strike in Australia. A friend's 91 formula 350 was one of those. It came with aluminum drums.
Old May 3, 2023 | 07:35 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yes the stock brakes are bad, they fade quickly during any spirited driving. There are many ways to improve the brakes and or outright replace them with an upgrade. As Sofa mentioned, you will be wheel size limited. A popular swap are LS1 brakes which can be purchased as a kit from big brake upgrade.com. You could also explore putting a 1LE kit together, although you'd probably spend as much as an LS1 set to have a system not any better.
Old May 3, 2023 | 02:44 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
hawks also offers a full 1LE repro kit now which is awesome... its not cheap but I find it very enticing https://www.hawksmotorsports.com/198...ake-kit-hawks/
Old May 3, 2023 | 04:27 PM
Scotty54's Avatar
Car: 91 Formula
Engine: 2005 LS2
Axle/Gears: 4.11
The LS1 and 1LE kits look great, but I was hoping I could gain some improvement with something less complex than swapping spindles.
What about a quality pad (semi-metallic most likely) with a better rotor? Can I see improvement retaining the stock caliper?
Old May 3, 2023 | 04:47 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I don't see any point spending money on rotors of same dimensions. You can experiment with a different set of pads if you want, it's not terribly expensive. But at the end of the day the biggest improvement is found in calipers, which often are associated with larger diameter rotors too. 12" front rotors are plenty sufficient.
the blur
Jan 11, 2010 06:15 AM
kwp289
Brakes
Sep 9, 2008 01:01 PM
GTAman
Jun 8, 2003 10:35 PM
Adam89F
Feb 19, 2001 06:57 PM
92fireaudio
Jan 1, 2001 07:23 PM
