What Ohm?
Old Oct 17, 2002 | 05:43 PM
82Z28_Camaro's Avatar
What Ohm?
I am planning on buying 3 10" Sony Xplod aluminum subs at 4ohm single coils each. What ohm will I be running if I bridge them all together? I think it will be 1. Thanx
Colby
Old Oct 17, 2002 | 05:56 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
http://www.maaudio.com/techsupport/b...ubwoofers.html
check this out, i like it
Brian
Old Oct 17, 2002 | 06:11 PM
SSaudio's Avatar
you'll see a 1ohm load, but your amp will see half of that...depending on the amp, that wouldn't be too healthy for it..good luck
Old Oct 19, 2002 | 10:08 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Three 4 Ohm voice coils in parallel will result in a load of one and a third ohms. Probably too low for any amplifier. The impedance varies with frequency and transients in the audio signal, so it will dip even lower than that at times.
I wouldn't do it.
Old Oct 19, 2002 | 12:00 PM
My amp is a Boss Audio Overdrive eries 1900 Watt 2-channel 1/2 ohm stable
Colby
Old Oct 19, 2002 | 12:09 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
1900 Watts you say?
Assuming 100% efficiency and running on 14.4 V this amplifier would require 132 Amps of current for 1900 Watts out.
That's a lot.
Old Oct 19, 2002 | 12:21 PM
Then perhaps you need to check out Cerwin Vega's 12,000 Watt 2-channel amp.
Colby
Old Oct 19, 2002 | 11:07 PM
mcss383's Avatar
Originally posted by rustydawg
1900 Watts you say?
That's a lot.
and making the HUGE assumption that the amp puts out anything NEAR it rated output.
Old Oct 20, 2002 | 01:18 AM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
it's easily checked by
How many amps are your fuses? and how many are their?
Fanatic1074
Oct 3, 2022 05:57 AM
Elephantismo
Feb 13, 2019 12:51 AM
lewandom
Oct 1, 2015 08:15 AM
ironbmt
Sep 27, 2015 06:00 AM
Shane87irocz
Sep 22, 2015 06:21 PM
